Turn signals Flasher location???
Old Feb 5, 2011 | 03:39 PM
Wilsss's Avatar
Default Turn signals Flasher location???
99.5 A4 1.8t I need to replace my flasher and dont know where its at. I understand it is under the steering wheel but I dont know the exact location. anybody???
Thanks
Old Feb 5, 2011 | 04:00 PM
colony777's Avatar
do you mean the relay or the stalk
Old Feb 5, 2011 | 04:42 PM
Andrew149's Avatar
Explain?
Old Feb 5, 2011 | 05:18 PM
auditech79's Avatar
That is hardly a question, and more info is needed.
If the flashers and turn signals aren't working you most likely need the relay which is the red triangle located in the center of the dash.
Old Feb 5, 2011 | 07:40 PM
Wilsss's Avatar
ok so when i put the signals the light stays on. It doesnt flash. So I bought the relay. but I dont know where it goes.
Old Feb 5, 2011 | 07:59 PM
NHolzschuh's Avatar
if you dont know where it goes, chances are you bought the tiny relay that goes inside of the hazard relay which is the red triangular button in your center counsel. its much easier and faster to buy the whole switch which includes the button(and is very obvious as to where it goes)
http://www.ecstuning.com/Audi-B5_A4-...elay/ES258927/ \
that's the part you need most likely.
Old Feb 5, 2011 | 08:48 PM
Wilsss's Avatar
Oh ok Thanks. I didnt buy that part. what i bought is a relay that looks exactly like the ones that are located under the steering wheel. the problem is that I dont know which one is the one i have to replace. Now, If I replace the one i am talking about, do i still need the one with the triangle??
Old Feb 5, 2011 | 08:54 PM
NHolzschuh's Avatar
no you wouldn't but i can almost guarantee the one i linked is what you need.(wich is what another member was trying to say) and i think almost everyone would agree.
now if you look for the DIY post to remove it, go to a junkyard and swipe one or 2 and you should be ok, i actually fixed mine.(i opened the black box, and fiddled with the relay inside and got it working. took like 30mins of actual work, 2.5hrs of work, research and a short write-up)
edit:just wanted to add, i have NO idea what other relay your speaking of, the piece u bought it prolly the relay INSIDE the part i linked
Old Feb 5, 2011 | 09:05 PM
NHolzschuh's Avatar
hey wilsss im heading out in a bit, if you're mechanically inclined, i have a post of how i fixed mine without replacing it. search for the DIY to remove it, then click on my name and i have a post on how to "fix" the relay inside so you dont need to get a whole new part.. pm me if you have questions or want the pictures. i proyll wont be back till 2-4am central time but will message you back or w/e asap
Old Feb 5, 2011 | 09:20 PM
Wilsss's Avatar
Cool NH. Thanks so much. I will fix it myself using ur post. u been of big help again, thanks a lot.
