unisettings?
Old Oct 29, 2010 | 02:22 PM
chris120391's Avatar
Question unisettings?
im planning on doing the diode mod on my car next week and i want to tweak what i can by using unisettings (which is a free download from unitronics?) my question is can i just buy a vag cable from ebay and plug it in and start tunning? or do i have to purchase other stuff like vag-com, or a licence for the cable etc.? any help would be appreciated.
Old Oct 29, 2010 | 03:06 PM
hiwords's Avatar
yes you can. i was able to do it simple tweaking with an ebay cable. there's no need to purchase anything other than the cable
Old Oct 29, 2010 | 03:57 PM
thanks. is there a certain type of cable i need to get? or from a certain seller or will any of the ebay ones work fine?
Old Oct 29, 2010 | 04:56 PM
Msnickbroderick's Avatar
Actual WIZARD
http://cgi.ebay.com/ebaymotors/VAG-C...ht_5317wt_1048
Thats the one I got, works fine with my XP netbook.
Old Oct 29, 2010 | 05:04 PM
hiwords's Avatar
i got mine from an ebay seller named alphabid.
Old Oct 29, 2010 | 06:44 PM
turbo kraut's Avatar
Tech Guru
i have an ebay cable i could sell you
pm me if you want it
Old Oct 29, 2010 | 07:27 PM
Mike-2ptzero's Avatar
That is exactly the same thing as Lemmiwinks and only works on the 2000+ A4 1.8t.
Also it just allows you to adjust the "value" in the ecu which moves the map up/down across the board.
Old Nov 2, 2010 | 02:43 AM
mike - i have an 01. so since adjusting it is only affecting the map value across the whole range, it would still run better (safer) than stock right?
turbo kraut - you got pm
Old Nov 2, 2010 | 04:46 AM
Must do logs before and after making any changes. Last thing you want to do is add too much timing and end up with a rod sticking out the side of the block.
Old Nov 3, 2010 | 04:15 AM
i know i dont want to add too much timing so i dont have detonation. but what exactly should i be logging? can i log with unisettings or do i need a vag com for that?
