upgrading to hid problem/question
So i bought a kit from VVME -- what crap those are.. the bulb constantly flickers when idling.. probly a bad ballast. Let alone when i hit a bump the whole bulb flickers like its not held in place inside the headlight housing.
Ive installed HID in my other audi's but ive never had this problem. Bad kit? Cheap products? Does ANYONE know a good kit to buy? Tired of getting made in China trash, but don't exactly know what it would take to put factory HID in - assuming it would be a different wiring harness under my hood. Im talking on my 02 1.8TQM B6 A4. I posted here because the B6 forums are next to dead. Thanks and please post comments/input here ! |
I've heard many good things about the VVME kit from people here. However, I never had first hand experience with them.
Have you tried contacting the company and telling them the problem you're having? |
The connection is bad. Check the input on the ballasts and the bulb plugs one of them is corroded or bent or missing a weather seal. Deal w/ it before it does actually cause damage and be glad its not a new Acura your replacing. Just worked on one today that the bulb was out on but it was due to a bad terminal and the terminal is only available w/ the ballast.... looking at 350 bux all together for 1 side! That doesn't include labor. The previous owner of my car had installed my kit poorly and left the ballast just hanging so my weather seal went bad and terminals got corroded for the input. Cleaned it up secured the ballast no problems since.
I agree with part of what you said...mine don't flicker at idle, but when I hit a bump, they do kind of bounce inside the light housing.
Originally Posted by RyanSweeney
(Post 1029595)
mine did that too so i flipped around the metal piece that holds them in to the housing, making them fit tighter |
Originally Posted by jskinny
(Post 1029598)
(Post 1029603)
You talking about that metal wire like thing?
it should just come out if you pinch each sides together. |
(Post 1029746)
yea, the clip thing that holds the headlight in the hole? sorry dont really know how else to describe it, but i think the normal h7 bulbs are a little different shaped so it fits those perfect but the hids arent snug with it so i flipped it around and its good. kind of hard to clip in and unclip though.
(Post 1029595)
Originally Posted by somebody5788
(Post 1029488)
who knows, every now and again im sure someone has to come across a "bad kit" so to speak.. check with them i bet they send you a new kit or side
Originally Posted by osin34
(Post 1031255)
