Is using an older Dodge Cummins turbo a possibility?
Old Dec 18, 2008 | 01:31 PM
Staticclism's Avatar
Default Is using an older Dodge Cummins turbo a possibility?
I was kicking around at a junkyard the other day and came across a wrecked '02 Dodge Cummins turbo diesel - it had been rolled, but most of the engine components were OK.
My question:
Is the turbo off that truck usable in a "DIY"-type big turbo upgrade for a 1998 Audi A4 1.8T Quattro? I could probably get it for free.
Old Dec 18, 2008 | 02:02 PM
cgroff5686's Avatar
I dontno man cause the 5.9 24 common rail didnt spool till about 2300 rpm and that is a5.9 that is pushing 320 hp and about 600 ft lbs so even if you manage to rig it up it would take alot to spool it and when it did it would tear i know when my 2004 spools it chirps through 1 and second and it is an automatic
Old Dec 18, 2008 | 02:10 PM
Jc61990's Avatar
i want a turbo from a semi...
Old Dec 18, 2008 | 03:59 PM
flynnr's Avatar
yeahhhhhh : ) i love hearing them take off at stop lights, you just hear that turbo spoolin hard ha
Old Dec 18, 2008 | 04:05 PM
airguard350's Avatar
Tech Guru
It's possible. There's a guy runnin' around my area with a 4 banger Ranger that has a Holset off a Cummins. Word is is he's pushin' 32 lbs. under full throttle.
Old Dec 18, 2008 | 04:32 PM
qUaTtRoA4's Avatar
sounds like alot of fabrication...if you are a great metal worker/welder, go for it...if not...I would say don't even think about it....
Old Dec 18, 2008 | 05:18 PM
It definitely does seem like quite a bit of work....I don't know, I might see if I can get if off the guy for dirt cheap and see if I can figure something out. I'm not particularly good with exhaust fabrication, but I know a guy who knows a guy. I'll have to ask around a bit. It sure is a tempting proposition.
Old Dec 18, 2008 | 05:25 PM
Tech Guru
Just talk to Mike@DTH about what you would need to do. I think his 1.8T is pushing 530 horse.
Old Dec 18, 2008 | 05:35 PM
qUaTtRoA4's Avatar
it's pushing 530 with a beat to **** turbo...he is going to be making alot more power when he gets his setup the way he wants it...
honestly...for all of the custom fab/custom tuning that this setup will need, you could just get a garret big turbo setup...
alot less hastle and time...
Old Dec 18, 2008 | 05:38 PM
Tech Guru
But with a Holset it'll be one of a kind! Some people are just such slackers!
