AudiForums.com
-   B5 Models (https://www.audiforums.com/forum/b5-models-69/)
-   -   Vacuum Check valve location? (https://www.audiforums.com/forum/b5-models-69/vacuum-check-valve-location-187841/)
Pbcrazy Oct 1, 2012 09:28 PM
So I'm going to replace my vacuum check valve as I think it might be part of the problem for my starting issues, I found some on eBay for about $10, but where is it located? It's a 98.5 A4 1.8TQ
meh. Oct 1, 2012 09:30 PM
By the airbox. Take off the top cover and it should be near the back of the airbox.
Pbcrazy Oct 1, 2012 09:38 PM
Ok so take off the air box (passenger side infront of firewall correct?)top and ill see it?
meh. Oct 1, 2012 09:55 PM
You should see this
http://files.chronosinteractive.com/...fault17519.jpg
Pbcrazy Oct 2, 2012 06:25 AM
Ok cool thanks!
MetalMan Oct 2, 2012 10:45 AM
There are an additional 2 check valves near/under the intake manifold. And there's a slightly larger black check valve at the back of the intake manifold for the brake booster.
Pbcrazy Oct 2, 2012 03:09 PM
Which one should I replace? I was told the check valve could be causing my long start up times
