Vacuum Check valve location?
Old Oct 1, 2012 | 09:28 PM
Pbcrazy's Avatar
Default Vacuum Check valve location?
So I'm going to replace my vacuum check valve as I think it might be part of the problem for my starting issues, I found some on eBay for about $10, but where is it located? It's a 98.5 A4 1.8TQ
Old Oct 1, 2012 | 09:30 PM
meh.'s Avatar
By the airbox. Take off the top cover and it should be near the back of the airbox.
Old Oct 1, 2012 | 09:38 PM
Pbcrazy's Avatar
Ok so take off the air box (passenger side infront of firewall correct?)top and ill see it?
Old Oct 1, 2012 | 09:55 PM
meh.'s Avatar
You should see this
Old Oct 2, 2012 | 06:25 AM
Pbcrazy's Avatar
Ok cool thanks!
Old Oct 2, 2012 | 10:45 AM
MetalMan's Avatar
There are an additional 2 check valves near/under the intake manifold. And there's a slightly larger black check valve at the back of the intake manifold for the brake booster.
Old Oct 2, 2012 | 03:09 PM
Pbcrazy's Avatar
Which one should I replace? I was told the check valve could be causing my long start up times
evilkowz
Sep 3, 2017 01:31 PM
rplets15
Jun 19, 2011 06:38 PM
ericp1.8T
Mar 1, 2010 07:40 AM
SunnyShaida
Nov 20, 2008 11:35 PM
mbond0009
Feb 4, 2007 03:02 PM
