Vag-Com fails to work for my 2001 1.8t quattro a4
Old May 20, 2014 | 04:32 PM
bmxfreekonwheelz1's Avatar
Default Vag-Com fails to work for my 2001 1.8t quattro a4
My buddy is a Volkswagen tech and has his own personal Vag-Com (latest version with latest USB cable) and we were go I g to try to activate the window roll up by remote entry buttons like most everyone else has. My problem is Vag-Com won't communicate with any of my body control modules at all. It links up just fine with my ECU but fails every time at any body control modules. Any help???
Old May 20, 2014 | 05:23 PM
Mad Cow's Avatar
The B5 doesn't have a BCM, you need to look for the central locks or central convenience module, I forget which.
Old May 20, 2014 | 09:47 PM
mtroxel's Avatar
Its central locks. See how to do it here.
Ross-Tech: VAG-COM: Audi B5 VAG-COM Info
Old May 21, 2014 | 08:37 AM
We tried everything. It literally only works on the ECU. I didn't remember what they were that we tried to connect too but I remember Vag-Com only worked on my ECU and nothing else. But thank you for the response!
Old May 21, 2014 | 08:41 AM
That's the guide we followed to get the right codes for the features. It was a no go. It wouldn't connect to anything but the ECU for the misfire counter and TBA. Aside from that, we didntvdo much with the ECU.
Old May 21, 2014 | 11:50 AM
Mad Cow's Avatar
Do you have an aftermarket radio, is your abs (or any other control unit) unit acting up? If you answered yes to any of those questions, unplug the offending part and try again.
Old May 21, 2014 | 02:59 PM
smittylube's Avatar
mine works so MC is right problem is in your cars network somewhere (I have the same car)
Old May 22, 2014 | 08:53 AM
It came with an aftermarket radio. I don't have not ever had a factory radio. That can mess up Vag-Com? What should I do to work around that? Hopefully I don't need a factory radio!
Old May 22, 2014 | 11:48 AM
MetalMan's Avatar
Ross Tech has a page describing the "Aftermarket Radio Problem":
Ross-Tech: VCDS: Afterrmarket Radio Problem
Old May 22, 2014 | 04:09 PM
adam044's Avatar
I know that VAG COM allows you to read engine codes and such on the Audis is there so,ethic else that it also does? Change setting or anything?
My main question is is it free? Do you just get a USB cable from amazon or something and download a program? This is a question I've had for a while actually.
