valve tank ventilation electrical malfunction
Old Jun 29, 2012 | 02:30 PM
A4driver17's Avatar
Default valve tank ventilation electrical malfunction
Hey guys i had a check engine light and it said p1409 valve tank ventilation electrical malfunction and i was wondering if anyone can tell me what this means? thanks in advance
Old Jun 30, 2012 | 11:36 AM
setiya_red's Avatar
you need to test the resistance on each injector it should be 12 - 20 omes. you should find at lest one bad injector per side. after you have done this get back with me and we will run a few more tests.
Old Jun 30, 2012 | 01:18 PM
A4driver17's Avatar
How do i go about checking the resistance? Do i need an ohms meter? and where would i put it to check the resistance? Thank you for the help!
Old Jun 30, 2012 | 04:15 PM
A4driver17's Avatar
So i tested the fuel injectors and they all read at 17 ohms. Anything else i can do now?
Jfk63
Mar 23, 2011 11:14 AM
BT5150
Jan 20, 2011 10:05 PM
johnblaze
Dec 13, 2006 07:16 PM
V!Link
Jan 9, 2005 10:14 PM
