Very hard to start once engine has warmed up
Old Oct 19, 2008 | 07:36 PM
shappie's Avatar
Default Very hard to start once engine has warmed up
A4 99 Avant- Starts OK when it is cold. Once warmed, then shut off, it becomes very hard to start. The starter turns the engine fine, but it will not fire. You have to play with the gas pedal abit and after about a min of starter cranking it will eventually catch. Once it finally starts, the idle starts to waver back and forth between 2000 and 2200 rpm. After a mile or so of driving everything is normal, idle at 950.
Can someone help out here?
Old Oct 19, 2008 | 07:54 PM
onepoint8tee's Avatar
Check for fault codes. If none, replace your engine coolant temp. sensor.
Old Oct 20, 2008 | 02:42 AM
redline380's Avatar
Legal Moderator
dont know what the problem is but dont ever run your starter for more than a few seconds!!!!!!! you said a minute of cranking and thats way too much. That is exactly how starters get burnt up. sorry to harp and preach but ive heard some bad stories that started out like yours. and they dont end with just a couple dollars being wasted. the most that should be done is ten seconds of cranking and thirty seconds of cooling down at a minimum!
Old Oct 21, 2008 | 12:59 AM
EpicWin's Avatar
I say check your fuel pressure regulator.
Old Oct 21, 2008 | 01:10 AM
Audi_Skydiver's Avatar
It's your Coolant Temp Sensor. I will put $10 on it. It's a cheap part even from the dealer ($10-$15).
Josh
Old Dec 2, 2008 | 09:50 AM
crabiolet's Avatar
can anyone on this forum advise the correct resistance to ground and the pin to pin values of ect sensor?
thanks
Old Dec 2, 2008 | 09:57 AM
Jc61990's Avatar
i got my ECTS at VW for 33$.. i called audi to see how much they wanted... it was 50$!
just go down to vw and say you have a passat wagon, if they ask for the vin cause its a 99. say its the old body style
Old Dec 2, 2008 | 11:29 AM
ghost6303's Avatar
thanks
its variable resistance depending on the temperature which makes it hard to measure. just go to ecstuning.com and buy a new one for like $8.
Old Apr 23, 2009 | 08:21 PM
mikeeboy82's Avatar
Hey did you ever fix this? I have same problem and p0118 code -coolant temp sensor voltage high- sounds like this is likely possibility. Did you try this fix, and did it work?
Old Apr 23, 2009 | 08:52 PM
The Bishop's Avatar
Third on the coolant temp sensor. Just make sure that you get the correct color, they come in blue and green.
rccks96
Aug 29, 2023 08:58 PM
mtizzle981
Nov 25, 2013 10:43 PM
shane.trammell
Aug 13, 2009 01:07 AM
mikeeboy82
Apr 23, 2009 10:22 PM
cmbcannon
Aug 24, 2008 12:09 AM
