Vibration 55-60 MPH
Old Jul 5, 2012 | 10:51 AM
mtroxel's Avatar
Pull the exhuast, then the heat shield. Wiggle the shaft in the center bearing, then out at the CV joints. Any movement is too much.
Old Jul 5, 2012 | 12:27 PM
redmond1501's Avatar
That's what I was afraid of. The manifold-to-downpipe studs look like they're snap if I try to unbolt the downpipes, so I'm dreading having to do that.
Old Jul 5, 2012 | 12:29 PM
mtroxel's Avatar
Leave the downpipes there. Just take the exhaust apart at those sleeves. That will give you enough room to do what you need to do.
Old Jul 5, 2012 | 12:34 PM
Okay, that works..
Old Jul 6, 2012 | 04:19 AM
MyA4Mobs's Avatar
I'm still encouraging my $15 solution. Hubcentric wheel rings. Had the same exact problem. 100% gone now.
Just go to any tire shop near you and have them hook you up with the right ones. Problem solved.
It's at least worth a shot...
Old Jul 6, 2012 | 07:11 AM
mtroxel's Avatar
Doesn't need 'em. He has OEM rims.
Old Feb 2, 2013 | 10:04 AM
01 Avant's Avatar
any updates on this - i have the same issue - balanced and rotated the tires and the vibration is still there around 55-60mph and not dependent on load so its defiantly rotational
Old Feb 2, 2013 | 10:43 AM
  #18
jonbonesjones's Avatar
Moderator
hub centric rings?? You have these right?
If not GTFO
Old Feb 2, 2013 | 11:01 PM
  #19
Even though the vibration was felt in the front seats and not the steering wheel, the main issue was with the front half shafts.
Replaced the following:
+ OEM rims, round and true
+ New tires
+ Front control arms (improved a little)
+ All three motor mounts and both transmission mounts (improved a little)
+ Driveshaft (improved a little)
+ Rear half shafts (improved a little)
+ Front half shafts (improved a LOT. there is a little vibration at 58mph but barely noticeable)
The driver's side shaft had a rusted area that was flaking away. My theory is that enough metal flaked off to make the shaft just barely out of balance at 55-60mph and somehow sent the vibration through the drivetrain instead of the wheel/steering rack.
Old Feb 2, 2013 | 11:40 PM
  #20
01 Avant's Avatar
i have oem wheels also
i noticed my l/f outer cv boot is torn but still has grease so ill be changing the complete shaft in the next few weeks when my control arm kit comes in
