Voltage drop problems???
Anyone have a problem where the voltage will drop randomly and fairly often?
I am having a problem where the voltage will drop causing the rpms to drop. It does it at idle and while cruising, but not really above 3k rpms. I am leaning towards the alternator, but opinions are welcomed. Thanks. Josh |
RE: Voltage drop problems???
Check the volt drop from the alternator charge cable to the + terminal on the battery. (engine not running)
If thats ok use your volt meter at the battery (engine running) and see if the voltage really is dropping. |
| All times are GMT -4. The time now is 12:40 AM. |
