Voltage drop problems???
Old Mar 24, 2008 | 04:37 PM
quattrosedan's Avatar
Default Voltage drop problems???
Anyone have a problem where the voltage will drop randomly and fairly often?
I am having a problem where the voltage will drop causing the rpms to drop. It does it at idle and while cruising, but not really above 3k rpms. I am leaning towards the alternator, but opinions are welcomed.
Thanks.
Josh
Old Mar 24, 2008 | 05:51 PM
auditech79's Avatar
Default RE: Voltage drop problems???
Check the volt drop from the alternator charge cable to the + terminal on the battery. (engine not running)
If thats ok use your volt meter at the battery (engine running) and see if the voltage really is dropping.
sukisuru
Feb 11, 2011 01:53 PM
Kara
Jul 24, 2009 03:07 AM
AAudiA6
Nov 30, 2006 05:18 PM
AAudiA6
Nov 29, 2006 08:26 PM
