weird engine rattle during moderate acceleration
Old Jun 8, 2009 | 12:41 AM
sony's Avatar
Unhappy weird engine rattle during moderate acceleration
Hi guys,
So I have this engine rattle on my 02 A4 1.8T thats been getting worse. It happens only during acceleration on the low end, kinda like the engine is lugging (its an automatic). When i hammer down to get the revs up, it goes away or if i accelerate hard from zero, I dont hear it either. Only hear it during low rpm acceleration. Any ideas??
Old Jun 8, 2009 | 12:57 AM
DÌEGØs AÜD!CTIØN's Avatar
could it be a loose heat-shield somewhere??
Old Jun 8, 2009 | 01:01 AM
sony's Avatar
Question
Hey Mexican 47,
I dont think its a heat shield. I'm gonna change the plugs tomorrow in case its misfiring or something. coilpacks maybe?
Old Jun 8, 2009 | 01:36 AM
my bad, so its coming from the actual engine??
is there any way you can check to see if theres any codes??
i think if it were a misfire or coilpacks you'd get a check engine light....
good luck, let me know if the plugs make any diff!
Old Jun 8, 2009 | 03:16 AM
xqwizit's Avatar
My guess is that your camshaft tensioner is going out. That's the mechanical device that holds the cam chain in place. When you accelerate, if there isn't enough tension, it rattles up and down and against the valve cover. Depending on how bad it is, I wouldn't say it's a necessary repair unless it's making that noise all the time.
Old Jun 8, 2009 | 06:52 AM
Isramirez21's Avatar
Are you sure is coming from the engine???
Sometime the catalizer makes a rattle noise when it's going bad and it makes it sound like if it'scoming from the engine.
Old Jun 8, 2009 | 12:57 PM
yeah thats wat i was sayin! or something like that lol
make sure its comin from the eng.
although the cam chain tensioner is a good posibility too
Old Jun 8, 2009 | 09:13 PM
sony's Avatar
Thanks for the advice guys.........so how do i differentiate whether the noise is coming from the cam tensioner of the catalytic conveter??
Old Sep 24, 2013 | 07:43 PM
Darius4's Avatar
Default Engine noise
Hi, did you sort out the problem u had with weird engine nose when accelerating? What was it? Thanks
Old Sep 24, 2013 | 07:45 PM
Darius4's Avatar
Iiiii
