Weird handling on rain
Whenever I get new tires installed (all four at once), I get them balanced (obviously) and I do my alignment. That should do the job.
There is a chance some of your control arms are shot. That can cause bad camber and other wheel issues.
So bottom line....Get the car aligned and check control arms
Weird thing is that on dry road it behaves really good....and sometimes in the rain as well....like a month ago I had to go in a long trip and it was raining like hell...I was doing around 120-140 km and the handling was good. But 3 days ago when I wrote that post I couldn't go over 70. I am not going to say that I am a good driver etc....but hell my car was like a rear wheel drive with diff lock! Ill keep you guys updated! Thanks a ton for all your help!
I mentioned the control arms because if they are worn out they will create too much clearance and you can experience looseness and rattle. I replaced my entire front control arm set, the rear I didn't replace cause its still tight.
