what to get
hey so ive been told i need coil packs to fix my mis fire but i went to the dealership and they tried selling me the coil pack assembly is this what i need?
if not what and where do i get and find coil packs please help me thank you all
you have a 2.8, that coilpack is for a 1.8t. 2.8's use three central coil packs that look like this
http://www.ecstuning.com/product_lib...ion%20Coil.jpg
it comes as one unit and should be somewhere around $200. a misfire could also be due to old plugs or wires, when were they last changed?
But anyway... same deal with the older V6 coil pack. Don't cheap out, get a genuine replacement. You'll usually find rust on older ones and the plastic will crack off. It's a tell-tale sign of a bad V6 coil pack.
And you will end up replacing these inferior packs in 5K miles when they crap out again. Coil packs should be purchased OEM ONLY. They have enough problems as it is, don't buy cheap imported (usually Chinese) crap. They are only $33 list each from the dealer. Don't but them elsewhere.
It had lasted me over a year now with more than 10K (pretty sure).
