what is this intake hose? What's it do?
Old Apr 30, 2009 | 11:00 PM
Pa Matt's Avatar
Default what is this intake hose? What's it do?
This isn't my setup, but i just put a K&N panel filter in and swiss cheesed the airbox. I noticed this line(The one that the tiny filter is attached to) is broke leading to some type of pump or something. What the heck is this? Something for emissions?
Old Apr 30, 2009 | 11:45 PM
Mike-2ptzero's Avatar
It goes to the secondary air pump that sits below the air box and feeds air thru one of the hard pipes that sits above your exhaust manifold to the valve sitting on the back of the head on the exhaust side.
Old May 1, 2009 | 07:42 AM
Pa Matt's Avatar
Is it something I need to replace if its cracked/broken on the lower side? Open air goes to it still obviously...
Old May 1, 2009 | 09:13 AM
Tweaked's Avatar
You should. The pump should be pulling in filtered air as not to destroy it.
Old May 1, 2009 | 11:21 AM
Pa Matt's Avatar
okay, I'm not gonna go oem and pay out the whazooo, but I'll get a patch piece to clamp/tape onto the broken section. Thanks for the help! What exactly does that air pump do? I'm new to audi's. I've owned, built, turbo'd many honda's and they don't have anything like this!
Old May 1, 2009 | 11:36 AM
It blows fresh air into the exhaust side of the head just behind the exhaust valves.
Old May 1, 2009 | 04:20 PM
Pa Matt's Avatar
ah, gotcha. did some reading and found that it helps with cold starts
Old May 1, 2009 | 04:42 PM
Helps for cold idle since it doesn't come on right as you start the car.
Old May 2, 2009 | 01:13 AM
Tweaked's Avatar
It's mainly for emissions. It helps the cat light-off on cold starts and is also used to test the O2 sensors.
Old May 3, 2018 | 10:57 PM
BoostinginmyB5's Avatar
Attachment 45178
What size and degree of elbow did you use for that??
crazyone
Jun 12, 2011 10:53 AM
DJF
Sep 16, 2009 04:04 PM
meanmuggin
Aug 26, 2008 11:09 AM
uruk
Nov 26, 2007 07:49 PM
Rizy102
Mar 8, 2006 08:04 PM
