this is what my warranty covers, is this legit
Old Feb 15, 2008 | 06:06 PM
tatensty's Avatar
Member
Default this is what my warranty covers, is this legit
seeming how you all now just about everything about audis i wanted to know if my warranty is bogus or is it actually legit. want to know if it covers tune ups and clutch
PRco's Open Road Premium Covered Components:
1. Engine All internally lubricated parts for rotary, gas and diesel engines; block; cylinder heads and barrels; turbocharger and supercharger housing and internal parts; waste gate and control valve; intercooler; timing belt, chain, gears, tensioner, idler and bolt; balance shaft, belt and bolt; all pulleys and their bolts; harmonic balancer and bolt; cam gear bolt; head bolts; intake and exhaust manifold; mounts; cushions; flex plate; flywheel; ring gears; timing and valve covers; oil filter adapter; oil pan; factory installed oil cooler, metal lines and fittings; dipstick and tube; coolant, lubricant, filters, seals and gaskets required for a covered repair;
Overheating: All of the parts listed above as a result of overheating caused by the failure of a covered part or the head gasket. This coverage applies to You if the covered vehicle has less than 100,001 miles on purchase date, as stated on the Application, and reported to Driver and Motor Vehicle Services as "is the actual mileage." If the covered vehicle has more than 100,000 miles on purchase date or is not actual mileage, this coverage does not apply. See contract for coverage limits.
2. Transmission Case and all internally lubricated parts; external electronic control unit; overdrive unit; torque converter; modulator; mounts; bell housing; external linkage; oil pan; oil cooler, metal cooler lines and fittings; dipstick and tube; lubricant, filters, seals and gaskets required for covered repair.
3. Drive Axle Assembly (Front and Rear) Drive axle case and all internally lubricated parts contained within the front or rear drive axle; thrust washers; drive shaft; "U" joints and yokes; double offset joints; CV joint and bearings; tripod joints and bearings; stub shaft; axle shaft; propeller shaft; center support bearing; locking hubs, hub assembly and bearings; flex disc; differential cover; lubricant, seals and gaskets required for covered repair.
4. Transfer Case Case and all internally lubricated parts; four wheel drive actuator; control module; viscous coupling; mount; shift motor; lubricant, seals and gaskets required for covered repair.
5. Basic Electrical Starter motor, drive and solenoid; alternator.
6. Basic Cooling Water pump; radiator; coolant, seals and gaskets required for covered repair.
7. Basic Fuel System Electric and mechanical fuel pump.
8. Steering (including four-wheel steering) Box, pump, pump housing and all internally lubricated parts within the box and pump housing; pump pulley, mounting bracket, external reservoir and cooler; valves; rack and pinion; steering main and intermediate shaft, pivot joint, couplings and bearings; knuckles; metal cooler lines; power steering hoses; power cylinder assembly; lubricant, seals and gaskets required for covered repair.
9. Brakes Master cylinder; vacuum assist booster and pump; power assist booster and valve; hydroboost; calipers; wheel cylinders; combination valve; load distribution valve; power brake cylinder; parking brake assembly; brake pedal assembly; backing plates; metal lines and fittings; fluid required for covered repair.
ABS electronic control processor, booster, solenoids, wheel speed sensors and excitors, relays and computer module, hydraulic pump/motor assembly, pressure modulator valve, accumulator, proportioning valves and control valves; fluid required for covered repair.
10. Suspension Upper and lower control arms, shafts and bushings; spindle and spindle support; upper and lower ball joints; wheel bearings; I-beams; leaf springs, their shackles and bushings; coil springs; linkage; tie rods, ends, and adjusting sleeves; centering lock spring; pitman, idler arms and bushings; radius arm and bushings; torsion bar, stabilizer bar, track bar and their mounts and bushings; center/drag link and bushings; king pins and bushings; double wishbone assembly; electronic level control compressor, sensors, relay and limiter valve.
11. Air Conditioning & Heating
Compressor and mounting bracket; clutch and field coil; idler pulley, bearing and mounting bracket; serpentine belt, tensioner, bearing and pulley; condenser; evaporator; receiver-drier; accumulator; expansion and POA valve; high/low compressor cutoff switch; pressure cycling switch; orifice tube; blower motor, fan and resistor; heater core; heater control valve; ducts; filter, refrigerant, oil, evacuate, recharge required for covered repair.
12. Select Electrical Front wiper motor including internal circuit board, relay module and delay switch; rear wiper motor; horn and relay; voltage regulator; power door lock actuators; power window motor, regulator and relays; convertible top motor.
13. Enhanced Electrical Alternator mounting bracket and pulley; electronic engine control module; distributor pole piece, shaft and housing; power seat motor, relays and manual seat adjustment; door and trunk lock solenoid; manually operated switches including those for power windows and seats, turn signals, cruise control, head lamps, brake lights, interior lamp; emergency warning flasher; neutral safety switch; backup light switch; brake light switch; head lamp relay; head lamp washer pump; temperature gauge sending unit; oil pressure sending unit and switch; rear window defogger or defroster; front and rear washer pumps; washer fluid exit ports; engine compartment wiring harness; engine oil level sensor; door-ajar switch.
14. Enhanced Cooling Radiator shroud and bracket; thermostat and housing; fan blades and clutch; flex fan; electric fan motor, relay and resistor block; coolant recovery tank; coolant level sensor; coolant required for covered repair.
15. Enhanced Fuel System Fuel injectors, nozzles and pressure regulator; injection and pump; distribution rails; electric fuel pump strainer; distributor; pulsator; sending unit; tank, filler neck, metal lines and fittings; accelerator pedal assembly; warm up regulator; pump relay; lift pump.
thanks in advanced for your time
chocalotstarfish
May 14, 2010 08:44 PM
99Quatt6
Jun 11, 2009 09:16 AM
Nicka430v
Apr 15, 2009 08:11 PM
Got2Speed
Mar 11, 2008 09:29 PM
cmckelvy
Nov 1, 2007 09:38 PM
