whats the A4's stock boost psi?
Old Dec 13, 2008 | 11:01 PM
RK's Avatar
RK
Member
Question whats the A4's stock boost psi?
i have a stock 98 A4 1.8t (AEB). i just instld a boost gage and it only reads up to 4psi max whn i step on it.
is that normal or is it in some limp mode?
i've already check for leaks and i have none and i have no codes.
thnks for the feedback !
;o)
Old Dec 13, 2008 | 11:43 PM
ty98a4's Avatar
hmm you must have something goin on. and i dont think your car has a 'limp mode", stock is around 7-8 psi i think
Old Dec 13, 2008 | 11:58 PM
somebody5788's Avatar
How much vacuum is it showing?
Old Dec 14, 2008 | 12:15 AM
Jc61990's Avatar
when idling not moving at all
Old Dec 14, 2008 | 12:24 AM
FASTER's Avatar
Tech Slut
yes it does, and its in it
Old Dec 14, 2008 | 12:45 PM
AutoUnionFan's Avatar
did you use vagcom to scan for codes or what? because I believe limp mode will throw a code somewhere
unconnecting battery for ~5 mins may reset limp mode
Old Dec 14, 2008 | 11:14 PM
RK's Avatar
RK
Member
i used an OBDII scan/erase to scan for any codes. at idle its at 20-21 In Hg. at speed its at 0. when i step on it, the gauge reads 3.5-4 psi at most.
the boost gauge is a VDO (30 In Hg - 25 psi) from apr
Old Dec 15, 2008 | 12:39 AM
qUaTtRoA4's Avatar
sounds like you are either in limp mode or you have a boost leak...
Old Dec 16, 2008 | 12:06 PM
RK's Avatar
RK
Member
i'll try disconnecting the bat for 5 min n see if the works. but how do u check for boost leaks? and whr the most common places for it to leak?
im just wondering, whats the highest you can boost a K03 and a k04?
once again, thnx guys for the info
Old Dec 16, 2008 | 12:11 PM
Stock boost should max out near 8psi, chips will max out near 20psi, anything over that is going to be risky for the ko3
sounds to me like a boost leak
