Whats this Airbag Code Mean?
Old Jan 15, 2009 | 01:29 AM
Broncoman75's Avatar
Default Whats this Airbag Code Mean?
Address 15: Airbags Labels: None
Part No: 8D0 959 655 M
Component: Airbag 7 Audi 0502
Coding: 00104
Shop #: WSC 06335
2 Faults Found:
01217 - Side Airbag Igniter; Driver Side (N199)
32-10 - Resistance too High - Intermittent
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
This is what i got when i pulled the code using my buddy at work's vag-com
is this from the connector under the seat that i read about being loose, or is it something else?
Old Jan 15, 2009 | 01:34 AM
DÌEGØs AÜD!CTIØN's Avatar
what car do u have? i have an airbag code on my b5 a4 too that i suspect/hope is the connector under the seat!
Old Jan 15, 2009 | 02:03 AM
sorry. its a 98 1.8t MQ
Old Jan 15, 2009 | 05:40 PM
oh. yeah i dont dont know what my codes are cuz i was using my friends vag-com and it said there was a chance the airbag system could be damaged if i scaneed them so i didnt. did urs say that too??
try reseting the codes and zip-tie the conector under the seat tight. and see if it comes back...
Old Jan 15, 2009 | 05:50 PM
ImTheDevil's Avatar
Here's the giveaway:
That means the connection is open intermittently, which is indicative of a plug that has been pulled slightly apart (open) and then relaxed and regained continuity. 99% it's the under-seat connection. Zip-tie, reset light, and see if it's a fix - it should be.
Old Jan 15, 2009 | 06:17 PM
dude thats pretty much what i said lol jp.
but does anyone know if vag-com can really damage the airbag system if scaned??
Old Jan 15, 2009 | 07:37 PM
AudiTurbo's Avatar
Remember I talked to you about this cause my airbag light was on and I just pushed in the on the airbag plug under the passenger side and took it to my buddy at VW and it's ok now! Check those plugs
I was looking for this a while back, cause my light has been on for a while and the day after I fix mine I find info!
Thanks Devil for the Help!
Old Jan 15, 2009 | 10:42 PM
ok, thats what i was hoping.
I know i saw a picture somewhere of someone showing this plug and how to zip tie it, but i searched and searched and cant find the picture, can someone point it out for me if you know what im talking about?
thanks
Old Jan 15, 2009 | 11:09 PM
ImTheDevil's Avatar
It's in my photo album. Click my screenname to go to my profile, and my album link is on the righthand side. The pic is in there.
Old Jan 15, 2009 | 11:18 PM
AudiTurbo's Avatar
That picture helped me!
