Whats next? CC Q's
Old Dec 6, 2011 | 05:33 PM
viperpit07's Avatar
Default Whats next? CC Q's
ik there are threads on fixing cruise control but im asking specifically cause im in class rite now and have the opportunity to work on it. ive checked the box under the glove box for4 cracked solders, taken off the tree and used electrical contact cleaner oon it to clean it. and checked the fuses and they are all good. i dont know what else to check to get the CC working, nothing happens, no lights when i turn it on and nothing when i press the switch its entirely dead, everything else on the car works to my knowledge all lights and other funtions. and tips would be great guys thanks
Old Dec 6, 2011 | 07:11 PM
MetalMan's Avatar
Just for clarification, there is no light to indicate the CC is on or being used.
Which solder joints did you reflow on the CC module? On mine I used a soldering iron to put fresh solder on the joints for 3 square capacitors, I think they were yellow. After cleaning the contacts on CC switch this allowed the CC to start working.
I have a whole folder of bookmarks dedicated to CC repair for the B5, but it's on my computer at home. These go through further diagnostics which may be useful to you. I can post up the links later.
Old Dec 6, 2011 | 07:54 PM
MetalMan's Avatar
This is what I followed for resoldering components on the CC module:
https://www.audiforums.com/forum/diy...ule-fix-57846/
https://www.audiforums.com/forum/b5-...1/#post1212463
Long, but good diagnostic if the above doesn't work:
http://search.audiworld.com/showpost...28&postcount=1
Another DIY fix:
http://forums.audiworld.com/showthread.php?p=1936114
Old Dec 6, 2011 | 08:16 PM
viperpit07's Avatar
Thanks man ill look into it. I didnt solder anything on the cc pcm, it all looked good my auto tech teacher even okayed it for me. And i just took apart and cleaned the switch again ill see if it works. Will any lights come on when i set the cc if it works? Or will i now know unless it accelerates fot me?
Old Dec 6, 2011 | 09:07 PM
viperpit07's Avatar
so i was checking my vaccum pump **** out removed my throttle body hose and found a tiny bit of oil in it so my turbo is leaking oil, grand isnt it! so on average is a rebuild or a new turbo cheaper? its not leakin very bad i checked all the hoses and its just kinda moist and a tiny puddle here and there, so i wont worry about it any time real soon.
Old Dec 7, 2011 | 07:14 AM
cnigro1279's Avatar
In the same boat right now. I've been working on getting my cc fixed for a while now and am thinking I have a vacuum problem as well. Re-flowed my cc module and can now hear the audible 'click' on the module when I engage the switch so my stalk switches should be ok. Gonna check my actuator, vacuum pump, brake and clutch switches this weekend. What a PITA.
Old Dec 7, 2011 | 12:27 PM
MetalMan's Avatar
You can't necessarily tell a bad/broken solder joint by its outside appearance. This is why the solder should be reflowed regardless as the DIYs mention.
You will know CC works when it works LOL. There is no indicator anywhere. As cnigro1279 said the relay in the module will make a slight click when CC is engaged, but you would need the glove box open, music turned off, etc. to hear it. With the intake/exhaust setup in my car you wouldn't hear the CC relay click anyways
New turbos aren't cheaper. Some people will get a used lower mileage turbo for less money than a rebuild, you would need to check the classifieds for one. If you did get your turbo rebuilt you'd have to wait for it. Buying a new turbo is convenient because it is ready to be dropped in as soon as you are.
As for the clutch/brake switches, be aware that they might not work the same as indicated by the DIYs I listed. My switches worked in a different manner but it took a couple hours of head-scratching for me to realize it. Unfortunately I no longer recall how mine worked (relative to the DIYs).
Old Dec 7, 2011 | 02:21 PM
viperpit07's Avatar
yea my turbo is fine apparently had my budy look at it, its just oil from the crankcase and extra moisture. but the CC still doesnt work i will try reflowing some of the solder but idk what yet, but ill see if it clicks first, all the vaccum stuff looked and seemed good, but i couldnt get the damn line off to check clutch and brake funtion.
Old Dec 7, 2011 | 02:26 PM
MetalMan's Avatar
The CC relay will only click if cruise control in general works. So good CC=click, bad CC=no click.
Old Dec 7, 2011 | 04:24 PM
viperpit07's Avatar
Ill prob try redoin some solders that any suggestions?
Duffman6
Oct 26, 2011 01:44 PM
jss
Nov 16, 2008 09:50 PM
McGovs2.7TB5
Nov 3, 2007 05:25 PM
tse07
Oct 29, 2007 08:38 PM
Jeff
Jan 21, 2006 12:02 PM
