What's Up with My Fuel Gauge?
Old Feb 21, 2014 | 02:20 PM
soulstep's Avatar
Originally Posted by MetalMan
Just thought I would address this point: The tanks are supposed to hold 16 gallons. When my fuel light goes on, I fill up less than 14 gallons (usually ~13.5-13.8).
Once the pump clicks off, unless you know it didn't fill up completely (like shutting off after a couple gallons), don't fill up any further. You'll do damage to your charcoal canister, and over time this can make filling up more and more difficult.
I did not know that. That's good information to know! And to tell the gas companies who fill our cars for us (they always try to increase it to the next .50 or dollar).
Old Feb 21, 2014 | 02:56 PM
MetalMan's Avatar
Ah, I didn't even think about full service gas stations. Much of the U.S. has self-service gas stations.
Old Feb 21, 2014 | 06:59 PM
adam044's Avatar
I know it's not good to put more gas in once the pump shuts off. I only did it because it was telling me it was completely empty and I knew 11 gallons wasn't enough to fill it when it shut off. I know now that the gauge is just off which I didn't know before I did it.
Old Feb 26, 2014 | 07:37 PM
adam044's Avatar
Hoping I get a chance to look at this this weekend. So if it is the wire what should I replace the wire with? Any specific gauge or something? Figured I would ask now so I can be prepared.
I wonder what the problem will end up being. Hopefully it's just dirty contacts or something.
Old Feb 26, 2014 | 07:52 PM
mtroxel's Avatar
I just used the finest stranded copper I could find. That wire twists, slightly, every time the float moves, so you need something with a lot of flexibility.
Old Feb 26, 2014 | 07:56 PM
adam044's Avatar
So something you could find at a Home Depot or similar place?
Old Feb 26, 2014 | 07:57 PM
mtroxel's Avatar
Sure. Copper is copper.
Old Feb 26, 2014 | 08:00 PM
  #18
adam044's Avatar
Ok. Is it most likely the copper wire that's the problem?
Old Feb 26, 2014 | 08:01 PM
  #19
mtroxel's Avatar
No idea. It's a common problem with that part but I'm not making any bets. Invest $0.79 in a piece of copper stranded just in case. You only need about 2 inches.
Old Feb 26, 2014 | 08:05 PM
  #20
adam044's Avatar
Sounds good thanks
jaemako56
Nov 9, 2011 05:32 PM
mnorm757
B7 Models
May 11, 2011 04:00 PM
goodguytx
Jul 21, 2010 09:38 PM
EZAVANT
Apr 24, 2009 08:14 PM
rccks96
Jan 21, 2007 12:49 AM
