Wheel noise
Old Feb 16, 2014 | 12:34 PM
rmr1499's Avatar
Default Wheel noise
Ok I'm thinking it's a wheel bearing but let's see. This is my 96 Quattro. I know usually hard left you should hear it in right rear and hard right left rear. But when I go hard right I hear it in the right rear. And it isn't constant sometimes you will hear it sometimes you won't
Old Feb 16, 2014 | 08:39 PM
mtroxel's Avatar
The right/left rule is just a guide, it does not always work that way. Lots of times if you jack up a corner and turn the wheel with your hand, you can hear a bad bearing grind a little bit. I've heard of other guys who say to put your hand on the spring while you turn the wheel and you can feel it.
Old Feb 17, 2014 | 08:35 AM
adam044's Avatar
When my bearing was bad you could hear it all the time no matter what.
Old Feb 17, 2014 | 09:58 AM
rmr1499's Avatar
That's how it was on the 00 but all there is over there is wheel bearing or cv shaft so I'll order a new bearing
Old Feb 17, 2014 | 11:01 AM
rmr1499's Avatar
Ok what's better the timkien *** or national
Old Feb 17, 2014 | 06:13 PM
age2k2's Avatar
i know the feeling!
Old Feb 17, 2014 | 08:06 PM
adam044's Avatar
I've heard the *** is suppose to be very good. That's the one I would order if I was doing it.
Old Feb 17, 2014 | 11:48 PM
hartsoe1's Avatar
I'm surprised you are doing a wheel bearing when it isn't loud enough for you to be sure which one it is. this isn't an easy job on front - rear, easier. I've done both by removing wheel bearing housings and taking them to a shop for pressing. Maybe you have a Hub Shark or something to do it in place on the car.
Old Feb 18, 2014 | 03:36 AM
rmr1499's Avatar
Nah my mechanic does it for a good price that's why I'll do both at same time the car had 255k on it and I know I never did it
Old Feb 18, 2014 | 08:14 AM
adam044's Avatar
How much is 2 wheels bearings from the mechanic going to cost you?
