Wheel stuck to rotor
So it makes me feel like less of a man to admit this, but I can't get my right front wheel off of my car. I was planning on rotating my tires this weekend. I pulled the lugs from it and it's not budging.
I'm looking for some recommendations as to how to get it dislodged. I'm toying with the idea of lowering it back to the ground with the lugs removed (or very loose at least) so that the weight of the car can help dislodge it, but I was wondering if you guys had any other suggestions.
Thanks guys!
-Mike
Thanks guys!
-Mike
If the mallet doesn't work give this a try, it should knock it loose.
http://www.youtube.com/watch?v=TDDxq-3UTZE
Seriously tho, if needed you can put the lugs on 1/2 way and lower it, but be careful not to jack up the treads
Yeah happens to me from time to time too, its cause the wheels and rotors are made from dissimilar metals, so it promotes corrosion. I'm upgrading to zinc-plated rotors this spring, hopefully that'll help.
