Wheels/tires for '97 B5
Old May 30, 2010 | 01:21 PM
Azrael's Avatar
Default Wheels/tires for '97 B5
I got my brother's '97 A4 (2.8 quattro) when he bought his new one, and am in the process of restoring it. 2 of the wheels are in horrible shape.
I have a set of wheels left over from a previous car which are absolutely gorgeous with brand new tires. The problem is, the Audi sits on stock wheels/tires with tires rated 205/55R. The wheels/tires I have to put on are 225/55R.
I won't BS you guys. I'm pretty new when it comes to modding cars, so I could use some expertise. Is it possible to use the bigger wheels/tires without extensive modification? I'm not concerned about the speedometer, I'm concerned about this wrecking the stock brakes or even being feasible size-wise for ~10% bigger wheels. As far as I know, the car is currently 100% stock except for the exhaust.
Thanks in advance.
Old May 31, 2010 | 09:36 PM
Azrael's Avatar
No one can help? I thought it was a pretty simple question.
Old May 31, 2010 | 09:48 PM
chocalotstarfish's Avatar
Super Moderator
225 is the width of the tire, wont effect speedo. worst thing to worry about is running different height tires can jack the quattro, but I did it for 6+months
Old May 31, 2010 | 10:17 PM
aledelic42's Avatar
225 will definitely affect the height and speedo if all four tires were changed to that.....
225 = tire width = 225mm
55 = tire sidewall height = 55% of width = .55*225mm = ~124mm ... .55*205mm = ~113mm
16 = wheel diameter = 16" = ~406mm
225/55/16 tires = ~26" ... 205/50/16 tires = ~25"
25/24 - 1 = .042 = ~4% difference
you do not want to use tire sizes with over a 3% difference with quattro. don't use 225/55/16 and 205/55/16
Old Jun 1, 2010 | 08:00 AM
Super Moderator
Damn you! I did the wrong math! some how I got a 1% difference. I ran with 3-225/65 on my stocks and 1 225/55 nono!
Old Jun 1, 2010 | 09:32 AM
Azrael's Avatar
Well what are the odds it's going to kill me to run 'em for a couple thousand miles? I only need the car to survive this summer. After that I'm gone for a year active duty and when I get back I'll have enough cash to get the '04 S4 I'm looking at. Thanks for your help, guys!
Old Jun 29, 2010 | 04:43 PM
JSA43.0Q's Avatar
I have an 02 a4 quattro with sport suspension, can i go from my 205/50/17 to 225/50/17 without any rubbing or problems. 205 to 225 would just be a width not a hight increase right? The tire diameter is .79 bigger. Is this too much and does anyign have any experiance with these? chocalotstarfish were the 225/65 not huge?
Old Jul 4, 2010 | 02:10 PM
KinkySlayer's Avatar
please explain this? x.x
Old Jul 4, 2010 | 02:38 PM
Super Moderator
explain what? how running different height tires jack up the quattro?
Old Jul 4, 2010 | 06:56 PM
jjcrt2's Avatar
just make sure the wheels are 5x112 bolt pattern too
