Where to buy Turbo oil feed lines for 2.7T??
Old Nov 8, 2010 | 12:35 PM
nitrorocket's Avatar
Default Where to buy Turbo oil feed lines for 2.7T??
I am replacing the turbos on my 2001 2.7T with some big turbos and was going to buy new oil feed lines.
I called the local Audi dealer and even at my cost they were $275. Thats nuts. Who has the cheapest prices??
Thanks
Old Nov 8, 2010 | 12:42 PM
tware4021's Avatar
this is the A4 section! the S line section is down a little farther
Old Nov 8, 2010 | 01:16 PM
CCA4's Avatar
Old Nov 8, 2010 | 01:34 PM
Dont be a DB!! I searched everywhere... I only found one company called ECS that wants more then the dealer...
Did you find them all over google?? Show me where??
Old Nov 8, 2010 | 01:40 PM
CCA4's Avatar
Relax buddy, just havin a little fun
What are you replacing your K03's with? The oil feed lines will obviously be different sizes for different turbos. I recall reading a thread not too long ago about making your own oil feed lines, I'll see if I can find it.
Old Nov 8, 2010 | 01:44 PM
Thanks...
You comment just came at the wrong time, I have been wasting my whole day searching so I finally put a post up and got that. I was like Grrrrr!
Old Nov 8, 2010 | 01:48 PM
CCA4's Avatar
So what turbos are you replacing the K03's with??
Old Nov 8, 2010 | 01:55 PM
FASTER's Avatar
Tech Slut
Like cca4 says, the fittings will be dependent on the turbos, and the length of the lines will depend on what manifolds you are going to run. Call Ringer Racing, there's some whack job workin there named Mike that is pretty knowledgeable. RingerRacing.com
Old Nov 8, 2010 | 02:00 PM
CCA4's Avatar
i lol'd
Old Nov 8, 2010 | 02:36 PM
I have the Frankenturbo's. They are a little higher flow then an RS6 turbo...
I found JHM has the line set for like $210 but they are high prices on stuff besides that. So there has to be someone cheaper for OEM lines...
Thanks
nitrorocket
Nov 8, 2010 03:10 PM
nitrorocket
Nov 8, 2010 12:49 PM
Audacity
Jun 6, 2009 07:39 PM
hboost
Oct 1, 2007 01:00 PM
Blôwn
Feb 25, 2003 02:14 AM
