where are the relays located?
Old Feb 20, 2010 | 11:32 PM
auditech79's Avatar
If its starting to bog down in different gears now its almost guaranteed its the fuel pump.
Old Feb 20, 2010 | 11:42 PM
Msnickbroderick's Avatar
Actual WIZARD
Most of them are under the drivers side knee bolster, if you take your interior fuse cover off and look down there with a light, you should see blocks with numbers (aka relays)
Old Feb 21, 2010 | 01:56 AM
Mr. Phil's Avatar
well mr auditech... since everyone seems to hail u as the guru of knowledge... i found this... would this work? or can i find cheaper or better?
http://www.ecstuning.com/Audi-B5_A4-...Pump/ES251808/
Old Feb 21, 2010 | 03:08 PM
Mr. Phil's Avatar
also.. as far as the walbro pump above... is that a plug and play kinda thing or am i gonna have to buy other stuff with it as well? i really want my car working again, as i have class everyday
Old Feb 21, 2010 | 03:41 PM
auditech79's Avatar
Yeah that pump is made for your car. You just need a couple special tools to take the tank cap off, then removing the pump itself. The tools can cost you about $400 so i would have a euro shop slap it in for ya. It should only take an hour of labor because the access hole is under the rear bench seat.
Old Feb 21, 2010 | 04:52 PM
Mr. Phil's Avatar
well i found the pump, its right under the trunk lining behind rear passenger seat, it only looks like 3 screws hold the cover on it... but im gonna call around tomorrow and see what people would charge for it
Old Feb 21, 2010 | 05:05 PM
Mr. Phil's Avatar
also.. is there a diy anywhere? ive replace a couple fuel pumps before, my old 300z and my 240sx... and im sure we would have the tools at the shop at school... we have pretty much every tool u can think of lol... id rather do it myself as opposed to paying someone to do it
Old Feb 21, 2010 | 11:44 PM
  #18
auditech79's Avatar
Check audiworld, but i don't know of a DIY for the older models. Most of the fuel pumps that go bad are in B6's.
Old Feb 21, 2010 | 11:47 PM
  #19
Mr. Phil's Avatar
yea i kinda searched audiworld and audidiy and the only thing i found was for a fuel seal replacement lol
Old Feb 21, 2010 | 11:51 PM
  #20
auditech79's Avatar
Its not a common thing to happen on a B5, i actually forgot it was located in the trunk on the B5, all the other audis are under the seat on the passenger's side.
