Who has a Bentley Manual!?
Old Apr 26, 2010 | 01:59 AM
kayakman13's Avatar
Default Who has a Bentley Manual!?
I need the info on how to check for coilpacks functioning with VAG-COM. I was told there was info to see if the plugs were firing, you have to code some stuff into the ECU to run a diagnostics check? I'm not sure on specs, but if you have a Bentley, I bet you can find them for me! Please please please! My car has been sitting for weeks and I need to know whats wrong with it!
Old Apr 26, 2010 | 12:24 PM
Audacity's Avatar
if its misfiring it will throw a code...you can cross referrence codes on internet. theres a wiki somewhere. the vag should tell you what cyclinders are misfiring anyway.
Old Apr 26, 2010 | 03:31 PM
kayakman13's Avatar
It WAS misfiring, now it wont start. I think its not sparking, but I want to be sure. Cylinder two was a code, but it also had random misfires on all cylinders.
Old Apr 26, 2010 | 09:22 PM
LuigiVampa's Avatar
If you send me your email address and your engine code I will send you the scanned in pages from the Bentley manual you are looking for. The Bentley manual has different sections for each engine code - the tests are probably all the same regardless of engine type but I don't think you want all the pages.
Old Apr 27, 2010 | 09:16 AM
kayakman13's Avatar
jayhawkwill@msn.com
I've got a 1998 1.8T AEB, Thanks a ton!
Old Apr 27, 2010 | 10:11 PM
LuigiVampa's Avatar
I emailed you the ignition section of the Bentley manual. Hopefully it helps you.
Old Apr 27, 2010 | 10:14 PM
Msnickbroderick's Avatar
Actual WIZARD
You know the whole manual is on mediafire right?
Old Apr 27, 2010 | 11:22 PM
McFizzle's Avatar
it might be worth checking your dealer if they are under recall. I have an AWM and they replaced mine at no cost
GM03Allroad
Oct 3, 2011 12:06 PM
katiebear00
Apr 6, 2010 01:58 PM
DurTTy
Aug 15, 2007 09:13 PM
mjvss21
Jan 7, 2006 07:03 AM
apoch
Sep 22, 2005 05:12 PM
