who here has lowered their car themselves
Old Feb 7, 2008 | 12:13 AM
washyourrhands's Avatar
Default who here has lowered their car themselves
and how long did it take you to do it?
was it simple or did you have to go through a whole bunch of crap?
reason im asking is my friend has a 91 nsx and he put his shocks and springs on himself and it was a bitch cus there was a lot obstucting and stuff
we have a full lift so i was just estimating ill be without my car
im getting h&r and bilstein combo ifyou were wondering
so stoked=]
Old Feb 7, 2008 | 01:18 AM
1SIKA4's Avatar
Default RE: who here has lowered their car themselves
it took AGES!!!! haha only because the front springs where being a **** and the little plastic pieces that block the bolts on the top where like basically glued on there and we had to break them off and a bunch of crap it was craziness and then compress the springs, it took me a good 6 to 7 hours because of the problems!!! in the front and taking the time to compress ALL the springs, but when you get to the rear its easy but you still gonna have to compress the springs, for me i didnt have to compress the rear to get the springs on but i did have to in order to get the old springs off. If you never done it before there might be some things that will take some time doing because you have yet to figure out how to maneuver them out, they got tutorials on audiworld.com if you want more info but i dont think it should take you that long to do it your self but it will get tiring compressing a total of about 6 times and uncompressing another 6 times next time im going to use a impact wrench it will be alot faster...
Old Feb 7, 2008 | 01:55 AM
qUaTtRoA4's Avatar
it's a two person one day job...use some pb plaster and expect the unexpected!
when I say a day it may take between 5 and 7 hours depending on "obstructions" and the ammount you have drank in this period of time...
gl! I'm sure it will come together just fine!
don't forget to take lots of pictures!
Old Feb 7, 2008 | 01:58 AM
rhynolite's Avatar
SoCal Crew Member
Took me and a friend 6 hours to install coilovers in his garage with jack stands.
Only reason it took so long is because neither of us had done a FWD Audi before, but once we figured out one of the rears, the other side literally took all of 5 minutes, while the fronts took about 35 mins respectively. The 6 hours is from the moment the jack initially touched the car to the time that I had all 4 corners at the right height I wanted
Old Feb 7, 2008 | 02:04 AM
cstarky15's Avatar
It also depends on if you have siezed bolts or not too. some times they need to be cut off. so have a few extra to be safe. I would say that the longest part is adjusting everything to make them the same height or how you want it!!!
Old Feb 7, 2008 | 02:12 AM
Lazer Viking's Avatar
did mine the first time in about three hours
dont thouch the pinch bolt on the front control arms, it will seize
Old Feb 7, 2008 | 02:14 AM
thanks so much guys this really helps a lot
if someone could give me a list of tools they reccomend i use and extra parts i may need thatd be just great!
thanks again and i will get picture up as soon as i get it done
it will be a fewweeks prob tho
but im stoked!
Old Feb 7, 2008 | 02:20 AM
qUaTtRoA4's Avatar
http://www.audiworld.com/tech/wheel14.shtml
Good luck!
Old Feb 7, 2008 | 02:22 AM
wow thats perfect
thanks so much!!!
Old Feb 7, 2008 | 02:38 AM
The Russian's Avatar
it took me a while to get mine out... the struts were like 1/2 inch too long so i couldn't get it out... i ended up sayign **** it and jsut took a saw the them since i had coil overws to replace them anyway, other than tht its pretty easy job
