Why a bad oxygen sensor code
Old Aug 2, 2008 | 03:38 PM
saved4use's Avatar
Default Why a bad oxygen sensor code
I have a 2001 A4 1.8T 74,000 miles. I recently replaced both O2 sensors & the MAF. My CEL came on this morning. The code is a P0130 - Sensor 1 Bank 1.
My car was stalling last night and had a rough idle. Can someone please tell me why I'm getting a bad oxygen sensor code when I just replaced it 2 months ago?
Old Aug 2, 2008 | 08:48 PM
Bogie's Avatar
Did you use Bosch O2 sensors? Also check for vac leaks.
Old Aug 2, 2008 | 09:21 PM
saved4use's Avatar
Yes I did use the Bosch OEM sensors from the dealer.
My cam seals and gaskets are leaking.
Could that be allowing air into the system?
Old Aug 2, 2008 | 10:45 PM
Bogie's Avatar
Well you can replace the cam and crank seals when you do your timing belt. When was the last time that was done? Should do it every 80K miles or so, so at 74K have it done soon. ECS Tuning sells the Ultimate Timing Belt Kit w/ everything from coolant, w/p, timing belt, tensioner, crank seal, cam seal, t-stat, and all the other belts too. Just do it soon. What other gaskets are leaking?
Old Aug 3, 2008 | 12:01 PM
Tweaked's Avatar
Check the part number of the pre-cat O2 and make sure it's the right one for your car. There is a VIN split in 2001.
Also, what are the O2 sensor readings?
drft1
Jul 5, 2010 12:18 PM
inkhaton
Dec 26, 2007 01:00 PM
quattrolove
Nov 17, 2007 12:41 AM
brent07
Jan 19, 2007 03:57 PM
