Quck Questions , bank 2 sensor 2, oxygen sensor
Old Jan 17, 2007 | 02:25 PM
brent07's Avatar
Default Quck Questions , bank 2 sensor 2, oxygen sensor
need to replace my bank 2 sensor 2 oxygen sensor. will this one work ?
Bosch
Oxygen Sensor; Front Left/Right; OE Version; Four Wire; Heated
2 per car. Recommended replacement interval: 100,000 miles. part number:13842 at www.autohausaz.com
Old Jan 17, 2007 | 09:52 PM
brent07's Avatar
Default RE: Quck Questions , bank 2 sensor 2, oxygen sensor
bump... anyone ?
Old Jan 17, 2007 | 11:21 PM
klum00's Avatar
It should, I dont know for sure but all my experiences (quite a few) with AutohausAZ have been really good. They seem to know what they are talking about and their Customer Service is excellent. They actually called me one time when I didnt respond to one of their emails.
Old Jan 18, 2007 | 10:08 AM
david9999's Avatar
Don't know for sure, but if they have one for the post-catalytic converter, that is the one you should buy, as that is the one that is reading bad.
What code did you get, as sometimes there are other causes of a bad reading.
Old Jan 18, 2007 | 03:58 PM
brent07's Avatar
i also had running lean and running rich codes with a couple miss fires ... but i believe it's from the o2 sensor going bad. i don't have the code number
Old Jan 19, 2007 | 03:43 PM
brent07's Avatar
Are these easy to replace ? Or should i have the mechanic do it while he does my air bag?
Old Jan 19, 2007 | 03:49 PM
onepoint8tee's Avatar
Id check the MAF. If it goes bad it can cause you to run rich or lean, or both. If you ran rich that can cause a misfire which can cause unburt fuel to get into the cat which then can cause whack 02 sensor readings. What were the misfires? what cylinders? Could also be a bad coil pack resulting in the same faults. Hell i had a cracked spark plug that wasnt firing right, and gave me an 02 sensor fault along with the misfire codes.
Old Jan 19, 2007 | 03:57 PM
brent07's Avatar
yeah, i recently had a code for the MAF and that was cleaned and taken care of and nothing has returned on that laitley. after cleaning the MAF it helped a lot ! Now it's just reading a random missfire and the 02 sensor code was consistant. The mechanic did a test on the coil packs ( ohms? and resitance ) and he said they checked out ok. sooo i'm thinkin the o2 sensor. are they hard to replace?
lespaul2510
Jul 6, 2019 02:48 PM
panzerwagen
Dec 18, 2012 07:26 PM
reject902
Jul 24, 2010 11:35 PM
spiney
Jul 15, 2009 10:18 AM
NoFlyZone
Jul 14, 2005 11:32 AM
