wierd little window problem
Old Feb 26, 2009 | 01:11 PM
InfamousA4's Avatar
Default wierd little window problem
So we all know the cool window trick, hold the key and the windows roll up and down...so one day the rear driver side window won't go down, it'll go up but not down. Everything else is fine, the controls on both doors work fine, and like I said i can do the trick to roll it up, just not down........any ideas?
Old Mar 11, 2009 | 09:39 AM
justinclarke's Avatar
Well the windows are connected to the central locking pump with 2 wires (one for up and one for down). So when you try and roll the windows down maybe the wire for that is faulty.
This would explain why it works on the button as that will communicate directly with the windows controller (not via the central locking controller).
If you look on here for wiring diagram links for central locking etc then you should be able to find out which colour wires connect to what.
BraMas
Jan 30, 2009 11:51 PM
Brakisshuro
Sep 14, 2008 09:50 PM
motegiman07
Feb 19, 2008 02:10 PM
superfly78209
Sep 13, 2007 06:41 PM
intjinfj
Jun 13, 2006 10:56 PM
