wierd redline
Old Mar 7, 2008 | 12:50 PM
BOOSTME's Avatar
Default wierd redline
this may be happening because i have a tip but when ever i go wide open my car only hits around 4000 - 4500 and then shifts even in tip mode it wont let me go much higher that 4 grand what could be causing it? 2000 A4 1.8TQ
Old Mar 7, 2008 | 12:51 PM
rallyrcr150's Avatar
Default RE: wierd redline
Trading your car in for a standard
Old Mar 7, 2008 | 01:15 PM
A4 Effort's Avatar
Get yourself a tip-chip, and you'll see a dramatic improvement. I can take all of my gears well into the 6k range and beyond.
Old Mar 7, 2008 | 08:36 PM
vgo's Avatar
vgo
^ is that what it does? cuz mine can go just by the redline in tip mode and i dont have the tip-chip, but i'd be pressing hard on the gas.
try pressing hard on the gas. cuz i think if you let it gradually build up to 5k it will stop. its like a rpm-limiter.i dont know if our car has it, but i see it happen too. sometimes i would forget to change gears when under tip mode, and my rpm would drop or fluctuate around 4-4.5k as if its trying to tell me "your a moron, your not on auto mode"
Old Mar 7, 2008 | 09:24 PM
A4 Effort's Avatar
ORIGINAL: vgo
I'm not pressing all that hard on the gas when rolling thru gears. I really never tried to take my car into that kind of rpm range before i had my tip-chip, so i have nothing to compare it to. But i do know that when driving in auto-mode, the shift-points are moved up and the car doesn't do as much 'gear-hunting' as it used to - and when it does find a gear it likes, it'll grab it and go.
Old Mar 7, 2008 | 10:33 PM
cantdrive55's Avatar
Do you ever get any clunking with the tip-chip? Like when you are in traffic and activate the kickdown switch?
Old Mar 7, 2008 | 10:52 PM
A4 Effort's Avatar
ORIGINAL: cantdrive55
Can't say that i do. For the most part, the shifts are pretty smooth, but there are times the shifts canreally throw you forwardwhen driving thru town atlower speeds.But out on the highway, you can really notice a difference in the way the tranny responds when using the passing gear, or when kicking it down to 4th while in tip-mode.
Old Mar 8, 2008 | 02:49 AM
tooxtreme8813's Avatar
your car should be able to rev to 6800rpm regardless of wether or not you have a tip chip. something is not right i would get that checked out, vag it and see if you pull any codes
Old Mar 8, 2008 | 10:05 AM
kendalll's Avatar
^+1 your car should happily rev to the real redline
Old Mar 8, 2008 | 12:16 PM
2Sick's Avatar
Its a safety mode that audis have not letting it go past the 4000 mark it should work fine something could be wrong with your engine.
