windows again.
Old Mar 25, 2009 | 12:07 AM
Audacity's Avatar
Default windows again.
my windows work from the outside door lock. up and down. but not from the switches.any ideas?
Old Mar 25, 2009 | 12:00 PM
Audacity's Avatar
bump.
Old Mar 27, 2009 | 12:03 AM
Audacity's Avatar
a little help?
Old Mar 27, 2009 | 10:41 AM
acetrebo's Avatar
From the interior switch on the door:
roll the window all the way down by holding the switch down. Then, roll it all the way back up by holding the switch up.
Then, see if it lowers by just tapping the down button and releasing.
Old Mar 27, 2009 | 11:20 AM
Audacity's Avatar
no man the windows don't budge from the switches at alll. i can't get them to go down from inside the car.
Old Mar 27, 2009 | 11:28 AM
acetrebo's Avatar
I see, I misunderstood, thought you meant the one touch.
Checked your fuse box yet? Do any of the other windows work say, the rear will roll down if using the control on the rear door?
if the other widows will go down from that particular door, i would say either a fuse, or a loose conenction where the wires connect to that bank of switches on the driver door.
Good luck.
Old Mar 30, 2009 | 02:07 PM
Audacity's Avatar
there is no power window fuse. and none of the windows work from any switch. no backs from the back no backs from the front. and no sun roof. but like i said they work from the door lock. i've checked the connections in the doors under the kick panel and to the locking unit as well.
Old May 31, 2009 | 02:51 PM
snyder-man's Avatar
I'm having the exact same problem. My dome light is also staying on after the car starts. The problems started at the same time so I am pretty sure they are linked together. I was thinking it might have something to do with the key or the ignition switch.
Any luck???
Old May 11, 2010 | 11:45 PM
Windward's Avatar
Any luck???
My car just starting doing the same thing as yours. Did you figure it out?
Thanks,
Old Jul 20, 2010 | 03:58 PM
bkcox_S4's Avatar
my car is having the same issues... been searching all the forums and nobody seems to have any answers...
i just ordered a $10 fuse kit with over 100 pieces and plan on replacing any fuses related to the sun roof, or interior lighting and hope that works
