working on the sunroof
Old Mar 2, 2008 | 07:19 PM
YoungGentleman86's Avatar
Default working on the sunroof
I searched the forum to see if i could find the answer but couldnt. my problem is that one side of my sunroof stays tilted up and doesnt come down or anything. when i checked it out i realized the part that runs across the groove in the sunroof was not moving on that side (stuck for some reason) while the other side worked perfectly. Anyone have any solutions.
PS I checked my subs this afternoon and fixed them... bad wiring (kinda figured i didnt blow them).
Bad news is i went in for my state inspection and passed yes... but found out i gotta change my left front control arms and tie rod.
Old Mar 13, 2008 | 09:21 PM
Default RE: working on the sunroof
well when i move the sunroof *** the right side moves perfectly well (up and down and even wants to slide back and completely open) but the left side only can tilt up fully and when set to full close position it only closes half way. Like i said when i checked it the wheel only moves halfway in the track and gets stuck somehow. Here's a picture of how the sunroof looks.
Old Mar 14, 2008 | 12:29 PM
auditech79's Avatar
Sounds like the sunroof track is broken, put the glass in tilt. Then take out the plastic covers on both sides (from the inside) and there should be 3 T25 torx bolts on both sides. Remove those and take the glass out from the top. Now you should be able to get a good look at the track from above the car. If it seems like the track is broken your gonna need a new one.
Old Mar 14, 2008 | 01:42 PM
ok thanks man gonna do that tonight after this interview or tomorrow the latest.
matthewa4
Jul 20, 2015 02:41 PM
dawns
May 19, 2015 05:09 PM
Marinski
Apr 10, 2014 03:54 AM
onlyamasterofevildarth
Jul 26, 2011 07:16 PM
vtraudt
Jun 2, 2010 04:43 PM
