02 a4 1.8t start up issue (when it has not been started in 2-6 hours)
Old Apr 7, 2010 | 10:10 PM
tmic0723's Avatar
Default 02 a4 1.8t start up issue (when it has not been started in 2-6 hours)
i have an issue with starting up my car. the car cranks, but i just have to sit there for a few seconds before the car actually starts. it's tough to explain over the internet...
my main point is that it only happens when the car has not been run in 2-6 hours...if i start the car in the morning when it's been off for about 10 hours, the car starts right up without the issue. Same when I start it anything an hour and less after being run...
really strange and i don't know waht the cause is and am wondering what i could be looking at for cost.
Old Apr 8, 2010 | 08:36 AM
Myst420's Avatar
Do you have any CEL's? Do you have any problems starting you car right after filling up?
Old Apr 8, 2010 | 10:29 AM
shane.trammell's Avatar
Sounds like the engine speed sensor. The part is easy to put on, and not that expensive. Once the sensor gets bad enough it will give a CEL.
How many miles do you have and have you replaced your coolant temp sensor that is in the coolant flange?
Old Apr 8, 2010 | 12:10 PM
pa4ul's Avatar
Have u tested your battery alternator? Take ur car to any autostore and have them do a test to make sure u dont need a new battery or alt.
Old Apr 8, 2010 | 06:55 PM
tmic0723's Avatar
The battery is only two months old (had a new one put in when I purchased the car)... So I don't think it's that. The car cranks over just fine, just doesn't seem to actually initiate the start-up.
I do not have an CEL's...car runs awesome besides this issue with 2-6 hours. Today I drove the car 2 miles to school at 7:00 AM. I started the car back up at 6:00 PM and it started up just fine...So it's only at 2-6 hours and doesn't always happen. There's just sometimes I'll try to start it up and it will keep cranking cranking cranking trying to start, and it just won't actually start.
I guess it could be the speed sensor but honestly how would I know? I've only had the car 2 months so what's been replaced/previous issues I don't really know...
Car has 109,000 miles on it btw.
Old Apr 9, 2010 | 09:33 PM
Dan1969's Avatar
Again, so car cranks but doesn't start: Coolant temperature sensor.... they go bad waaaay to often.
To confirm: Open the key to the start position without starting the car (do this when the car normally acts up) and leave it there for approx 3-5 seconds, then close the key completely, then attempt to start the car, it should crank and start right away.
Old Apr 9, 2010 | 10:26 PM
tmic0723's Avatar
Ok. How much does a Coolant Temp Sensor cost?
Old Apr 12, 2010 | 12:17 PM
pa4ul's Avatar
dirt cheap under 10 bucks i believe. And they should have it at almost any auto parts store. Install is on a4mods.
Old Apr 12, 2010 | 10:13 PM
Dan1969's Avatar
Yes, actually they're like 20 bucks with the little o ring and retaining clip.
Old Apr 13, 2010 | 09:55 PM
tmic0723's Avatar
Ok. I'm going to take it in soon. Do I have to go to a dealer or can any mechanic get this part and install it? What should I say too? That I am sure it's either a coolant temp sensor or engine speed sensor?
