100K, What else beside timing belt?
I brought home a 2004 A4 1.8T, 6 speed last week. The only maintenance/repair that, I can say for sure, has been done to this car is the clutch was replaced in the last month as well as the valve cover gasket. The mechanic who did this work said the timing belt was fine.
I am skeptical of his visual inspection of the TB so I am planning to order a timing belt kit from ECS Tuning and change it. My question is; while it's torn apart for the TB change, what else should I change?
I see ECS has the coolant system refresh kits, which make sense since I will be draining the coolant, but is this really necessary? I don't have any coolant leaks currently, but if it's best to take care of it with the TB then I'm game.
I also see an option for a kevlar timing belt. Is this more for racing applications? Or will it extend the time between changes?
Thanks in advance.
Thanks in advance.
I also have to wonder if the OEM hydraulic tensioner would tension the kevlar belt properly since it is a much stiffer belt. Would a manual tensioner be the way to go with the kevlar belt?
I should say that my car is stock. A week ago, I would have said that I plan to keep it that way. But I can see where a little more HP/torque could be a good thing.
Nothing crazy of course.
nmdjr
B7 Models
13
Apr 10, 2012 10:04 AM
Audiguruforyou
Sep 20, 2011 01:31 AM
Jeffla
Jan 3, 2010 04:43 AM
fritz
Aug 12, 2007 02:55 PM
