19 Rimrub spacers
Old Sep 1, 2008 | 01:21 PM
pa4ul's Avatar
Default 19 Rimrub spacers
For All u that have 19 inch rims im running a 245/35/19 and when i hit bumps or dips or take turns sharp my tire rubs but i cant find excatly where its rubbing. Where do ur tires rub if they rub at all. Iam also planning on throwin sum 15mm spacers in the rear also should i do the front too or no?
Old Sep 1, 2008 | 10:52 PM
adotjdot's Avatar
Yeah i too have 19 rims (245/45/19) and when i got them they were rubbing. I put in some spacers (forget the size) on my rear wheels and it was fine from then on...but dont let chubby friends sit in the back or it cancels out the affect from the spacers.
p.s. another suggested option to me is to roll my fenders (where it rubs) like and inch which apparently works the same.
Old Sep 2, 2008 | 04:53 PM
pa4ul's Avatar
what is rolling your fenders?
Old Sep 2, 2008 | 06:40 PM
kwik_shift's Avatar
Rolling Fenders is when you flare out the bottom lip of the fender. They make a tool that clamps on to the hub and it rolls it out perfect. If you have skills you could use a baseball bat. My friend did it on his 240sx, with the baseball bat it came out ok, but then again its a Nissan not a Audi!
Old Sep 3, 2008 | 04:15 PM
pa4ul's Avatar
wow a baseball bat im still not sure on how this works i kinda got an idea. But i notice a area that looks like it rubs and its kinda high up on the fenderwell. and its only on the passenger side. I take pic and post when i off work. Can u explain a little more bout this fenderrolling
magnitude
B7 Models
10
Mar 8, 2012 12:06 PM
Mac_17
Feb 9, 2008 02:24 AM
Dr.S4
Jun 24, 2007 01:54 AM
EliteTuning1
Jun 21, 2007 09:04 AM
Mikefc626
Dec 12, 2006 03:43 PM
