2002 Audi A4 quattro 1.8t smells of exhaust or something while driving with the heat
Old Dec 28, 2013 | 05:21 PM
Johnskisalot's Avatar
Default 2002 Audi A4 quattro 1.8t smells of exhaust or something while driving with the heat
2002 Audi A4 quattro 1.8t smells of exhaust or something in the cabin while driving with the heat on. When I have the windows up it's bad. Sometimes I feel a bit ill.
Has anyone else experienced something similar to this?
I don't know if I am being asphyxiated (sp?) or not.
I sometimes feel a little ill.
Long drives I need to keep the windows down.
It maybe nothing??
I did recently replaced the heater core maybe that is a clue?
Everything was sealed fine...I believe.
Thanks
John
Old Dec 29, 2013 | 08:49 AM
CryptoStorm's Avatar
Cabin air filter is located on the passenger side of the battery compartment. Check the hood gasket between the engine compartment and the battery compartment.
If you had a exhaust leak in the engine bay it would be pretty obvious as it would be loud..
You could have a leak coming from the flex pipe after the cats (braided exhaust you can see under the car..
More likely your smelling burned oil from a leaky gasket dripping oil on the exhaust (ie valve cover gasket)..
Johnskisalot
Apr 3, 2014 02:40 PM
jen02
Jan 11, 2012 08:59 AM
ezlnh8u
Sep 19, 2007 11:50 PM
MyDreamCar
Feb 21, 2007 02:27 AM
ilikecars
Mar 21, 2006 02:35 AM
