2003 A4 Avant 3.0L Timing Belt Change Question
Old Mar 20, 2010 | 05:45 PM
WDSmith485's Avatar
Default 2003 A4 Avant 3.0L Timing Belt Change Question
I am buying a 2003 A4 Avant 3.0L Quattro with only 24,000 miles.
When do I change the timing belt? @ the mileage point or is the age a factor?
Thanks
Old Mar 20, 2010 | 06:24 PM
Dan1969's Avatar
Damn, that's low mileage. The Timing belt interval is Audi recommended at 90k miles, most Audi guys do it between 75-85k miles. You might want to check the belt since is already 7 years old though, open the little cover with a torx screwdriver and look at the belt, if it looks a little too worn or there's cracks present is probably time for a new one.
Old Mar 21, 2010 | 11:10 PM
auditech79's Avatar
I would just replace it in the near future, that belt just won't last that long, even with only 24k on the clock. If the belt breaks you're looking at a repair bill between $3,000-$6,000 from bent valves/dinged pistons.
gabby456789
Jun 12, 2015 07:22 PM
Exuberantt
Dec 30, 2013 04:18 PM
Raybbaby
Aug 4, 2013 02:08 AM
mikekirchner
Jan 29, 2009 10:32 AM
