2003 A4 - Problem --- HELP!!
Old Mar 19, 2009 | 05:25 PM
smith566's Avatar
Default 2003 A4 - Problem --- HELP!!
Two of my ignition coils went out - it was under warranty and was towed to dealer who replaced 2 of the coils and 4 spark plugs.
I got it back and all seemed fine for a few days - Then it started to act like it did right before the others went bad ----
Warranty since expired, so I replaced the other two ignition coils myself, with some I got from Autozone. It did not help.
It seems to idle loud- and when i drive in the 40 to 60 mile an hour range, it feels like it isnt getting enough gas. Like it is missing and it vibrates alot. When I let off the gas, it runs fine.
I dont know what to check next - any suggestions???
Thanks!!
Old Mar 19, 2009 | 05:27 PM
shane.trammell's Avatar
Is the check engine light on?
Old Mar 19, 2009 | 05:41 PM
smith566's Avatar
No - the check engine light is not on.
Old Mar 19, 2009 | 05:48 PM
pa4ul's Avatar
check vaccume lines make sure all your check valves arent correided. I order my coils from ecs and got the hiatchi e coils no problems since then.
Old Mar 19, 2009 | 08:54 PM
smith566's Avatar
Could it be the ignitors?
Old Mar 19, 2009 | 10:17 PM
Dylan19's Avatar
I did the same.
Old Mar 19, 2009 | 11:02 PM
euro_2nr's Avatar
Just get the Hitachi E coilpacks. Replace all 4 when you do so
Old Mar 20, 2009 | 11:31 AM
pa4ul's Avatar
^x2 on this
Old Mar 21, 2009 | 09:54 AM
JohnA4Denver's Avatar
I have an 2002 1.8T and when I had a coil failure, the dealer replaced all four stating that "...this is a recall item...". Not sure if that's the case with a 2003, but worth a look.
Old Mar 21, 2009 | 10:22 AM
kwik_shift's Avatar
When coil packs blow, it is wise to replace all four, if you can get Hitachi "e" like stated above. If you replace crap with crap, then its gonna run like crap. I would double check the gap on the spark plugs, just in case.
