2004 b6 front hub question
Old Jul 7, 2010 | 10:48 PM
04-pos-a4's Avatar
Default 2004 b6 front hub question
anyone ever change one. doesnt look that hard. i pulled off wheel, caliper, and rotor. looks like all i have to do is pull cv shaft, and take off the 4 bolts holding on hub, and instal new one. Anyone verify this for me?
Old Jul 8, 2010 | 01:07 PM
mjfrizz's Avatar
Default need press
for wheel bearing
Old Jul 8, 2010 | 11:18 PM
04-pos-a4's Avatar
so it needs to be pressed on and off? not a problem if so. thanks for the pic!!
Old Jul 9, 2010 | 08:39 AM
mjfrizz's Avatar
yes...are you replacing the bearing too? might be a good idea as long as you are changing the hub...then you only have to press the new bearing...and you can trash or do whatever with the old bearing/hub assy
Old Jul 9, 2010 | 08:40 AM
mjfrizz's Avatar
as you can kind of see from the pic...the hub actually presses into the ID of the bushing
Old Jul 11, 2010 | 10:21 PM
04-pos-a4's Avatar
im going to buy the same bearing assem. as u have in the pic. i will press out the hub, and press it in the new bearing assem.
firnum
Feb 26, 2014 01:20 PM
cudafish
Jan 6, 2014 10:47 PM
quiksilverly
Oct 7, 2012 03:01 PM
maj
Aug 30, 2012 11:27 AM
dmpp
Mar 29, 2006 10:04 PM
