3.0 Clutch Replacement - Stuck!
Old Mar 6, 2010 | 10:57 AM
MingDriver's Avatar
Default 3.0 Clutch Replacement - Stuck!
I'm in them middle of a clutch replacement on my '03 A4 3.0 Quattro. Things were going fairly smoothly until it was time to remove the lower 3 engine to transmission bolts. The Bently manual says to jack the trans up a bit and take the bolts out - no further explanation - but I don't see how that's even possible. The trans/engine is jacked up as high as it'll go and I still don't have clearance to get in with a tool. The bolts are 8mm female allan head and I just can't get a socket or even an allan wrench in there without knocking the cross member. If they were regular hex head bolts I could get a wrench on maybe, but there's no room to go in from the front. Anyone deal with this before?
Old Mar 6, 2010 | 04:07 PM
R.A.I. Motorsport's Avatar
Former Sponsor
remove the rear subframe bolts and loosen the front subframe bolts, this should allow for you to remove them a bit easier. Having a good set of ball hex would really help out, but you will be able to get it out this way.
Old Mar 6, 2010 | 10:42 PM
MingDriver's Avatar
Thanks for the response. I finally gave up and removed the whole subframe. I just couldn't see any possible way around it. Allen wrenches didn't have the leverage or freedom of movement and there was no way I was getting a ratchet and hex socket in there. Much easier to finish the trans removal with the subframe out!
zero-o-matic
Mar 18, 2015 05:25 PM
meierba
Dec 18, 2009 06:55 PM
ricky0323
Sep 26, 2008 10:03 PM
sstockman
Jan 19, 2006 12:13 PM
sstockman
Nov 28, 2005 04:52 PM
