425awhp....
Old Apr 25, 2010 | 11:21 AM
zmadman210's Avatar
Default 425awhp....
I want 425awhp. So what did I do? Pull my engine and do a PTE 5857 build. It was the only logical choice that I had.
I'm bored at work, so I figured that I would start my build thread.
I have some really crappy pics that I took with my crappy cell phone (I know, double fail) and so I only have terrible pics to show you as of now. I'll take better ones later.
As far as the build goes, I want to keep it pretty basic.
-Engine
- IE rods w/ stock pistons new rings and rod bearings
- A refreshing hone for the block
- Port and polish AMB head
- AEB intake mani
- Exhaust valves
- Supertech valve springs w/ titanium retainers
- Stock cams (as of right now)
-Tuning/Fueling
- Probably Unitronic or Maestro... I want to run 1000cc injectors, so whoever can give me tuning for it
- 005 intank pump
- stock fuel lines w/ "returnless" system
-Cooling
- Treadstone TR10 w/ custom 2.5" piping
- Possibly W/M
-Turbo Stuff
- PTE HP5857SP (running like, 1 million PSI)
- Hoping the Treadstone manifold will fit, otherwise idk
- Tial wastegate
- Hallman MBC
-Exhaust
- Custom 3" downpipe w/ wastegate routed into it
- downpipe -> 24" cherry bomb 3" in/out to 2.5" Y to 2.5" out the back
-Clutch
- Something big and ugly from CM. I was thinking something like the FX850
Thanks to Clay@CTS for the Turbo and Clint@RAI for the awesome deal on the bottom end parts!
FILE0051.jpg?t=1270854881
Old Apr 25, 2010 | 09:25 PM
turbo kraut's Avatar
Tech Guru
nice... good luck with the build
Old Apr 26, 2010 | 07:42 AM
zmadman210's Avatar
Thanks
Old Apr 27, 2010 | 12:19 PM
Mike-2ptzero's Avatar
You really should upgrade the fuel line to -6 which will flow more fuel then the stock. Once you start having a need for more fuel then what the line will flow you end up getting a pressure drop which in turn forces the ecu to open the injectors longer.
Old Apr 29, 2010 | 09:34 PM
zmadman210's Avatar
I'm pretty sure after I get it together I'm just going to switch it out with a B5 return system with -6an lines if I can't get at least 400awhp :thumbs up:
Old Apr 29, 2010 | 09:35 PM
zmadman210's Avatar
bottom end is assembled
sorry for the crappy pics
Old Apr 29, 2010 | 11:16 PM
We were able to make 465whp on a B6 non return system with -6 line and 040 pump, no fuel pressure drop. After that point going b5 return setup helps since you would have to run 1000cc injectors just to reach 500whp on a non return system.
Old Apr 30, 2010 | 11:30 AM
zmadman210's Avatar
Thats some really good info.
