A4 1.8t quattro clutch peddal stuck to floor
Old Nov 28, 2008 | 03:28 PM
mdemisem's Avatar
Default A4 1.8t quattro clutch peddal stuck to floor
yesterday just driving along normally i went to shift and found that my clutch pedal was already fully depressed ...i pulled over pulled the pedal back up and it goes down and returns but feels extremly soft and only disengages the clutch about halfway with makes it impossible to drive (got it home by power shifting)...i already ordered a clutch slave but am not sure if thats the issue... any input would be greatly apreciated. Thanks in advance
edit: btw its a 2003
Old Nov 28, 2008 | 05:03 PM
mdemisem's Avatar
<bump> anyone..i know it hasnt been up that long but has anyone had this same problem or problem like this ?
Old Nov 29, 2008 | 04:09 PM
mdemisem's Avatar
bump.
Old Nov 29, 2008 | 10:21 PM
Mike-2ptzero's Avatar
Try bleeding the slave but your slave might be bad.
Old Dec 1, 2008 | 12:40 PM
mdemisem's Avatar
thats what im thinking too is there a master for this or does it share the brake master
Old Dec 3, 2008 | 10:33 PM
bloke's Avatar
any luck on this? I'm curious to what the answer is....sorry I can't really provide any helpful information.
Old Dec 4, 2008 | 06:42 AM
mdemisem's Avatar
not yet...going to the post office to pick up my slave tonight and ill probably also throw it in ill keep everyone updated though!
Old Dec 6, 2008 | 11:29 AM
mdemisem's Avatar
Replaced slave... no change no matter how much i pump it up the pedal never gets firm again...i tried bleeding it for a good hour no luck.. any ideas >?? help!
Old Dec 6, 2008 | 02:37 PM
When you put the slave in did you feel tension on the fork and did the old slave that you pulled out look good?
If its not the clutch or slave, you must have a leak in the system somewhere.
Old Dec 6, 2008 | 08:33 PM
mdemisem's Avatar
yeah i mean it looked good and felt ok... the fork seemed to have pressure on it i got a screw driver and tried to push it in but i couldnt... i have no idea where to go im just hoping the clutch itself isnt bad
