airbag fault
Old Mar 21, 2013 | 01:51 PM
johnmorgan1948's Avatar
Default airbag fault
Hi
I'm new to this forum and just wondered if anyone is knowledgeable about airbag fault on A4 b6.
Airbag lamp is on.
I've got vagcom and it gives me
"00859 Airbag igniter 1 Passenger side (N131)
001- Upper limit exceeded
I can turn it off, but it returns after 3-5 seconds
I've read a lot of posts about this fault and the consensus is it's the cable under the seat, I only have one cable, plugs into the floor connector and goes straight under the seat squab with no intermediate plug.
Also is the error code relating to the seat bolster bag, dash bag or curtain bag and what does "upper limit exceeded" mean?
Thanks in anticipation
Old Mar 23, 2013 | 12:32 PM
Default talking to myself
Putting this up for info, may be useful to someone.
After getting no response re which airbag 0589 related to, I disconnected the seat one from the floor and another fault came up, replaced connector and cleared fault, left with original 0589 code.
So 0589 is passenger dash bag, removed glove box discovered dislodged plug (loom to airbag) reconnected, cleared fault code, no air bag lamp, so I am a happy chappie.
Old May 23, 2013 | 03:07 PM
dre.hibnet's Avatar
I'm getting a code "01217 - side airbag igniter: driver side (n199) 001 - upper limit exceeded - imtermittent" when i connect and do a check using vcds. what steps excatly did you do before checking the connector cables (airbags are probably the only thing on the car that intimidates me when it comes to moving around connections) and do i need to have anything done via the dealer before?
tenstringer009
Jan 1, 2014 11:03 PM
vserghi
Jun 22, 2009 07:33 AM
jluckuck
May 17, 2008 04:04 PM
djlouieboom
May 15, 2008 06:35 PM
gwaxman
Feb 12, 2006 12:41 PM
