B6 rear door panel removal
Old Aug 22, 2009 | 04:08 PM
Quattro12's Avatar
Post B6 rear door panel removal
I've been trying to remove the rear interior door panel on my 2002 A4 and I'm currently at a loss as to what to do now. I removed the fake wood trim piece and the three screws behind it. There's four small clips here as well. They don't seem to do much of anything but I removed them anyway. Problem is, it won't budge in any direction and I don't see any more clips or screws. I don't want to break anything. Any help is appreciated!! Thanks!
Old Aug 22, 2009 | 07:01 PM
Dan1969's Avatar
There's a sticky called "window regulator DIY" that shows how to remove the panel on the front, I'm sure the rear one is similar.
Old Aug 27, 2009 | 10:31 PM
kwik_shift's Avatar
Once you figure it out, the rest are a piece of cake!!
Old Aug 28, 2009 | 04:32 PM
Quattro12's Avatar
Yeah, thanks for the help guys! Once I found the screw under the door handle it came off quite easily. Now my interior door handle works again
Old Aug 31, 2009 | 03:54 PM
kchao2000's Avatar
There are few black plastic clips holding the door panel as well. I can't remember exactly how many, might be 5. They are very easy to break when you pop the panel out. If you break them, make sure replace with new ones. It may caused rattles in the future if you don't replace them.
BTW, if your car is a 3.0 and has wood trim, they are real wood; not fake wood.
patandanna69
Feb 8, 2014 04:12 PM
adam
Nov 27, 2007 10:57 AM
beefski
Oct 24, 2005 07:11 PM
beefski
Oct 22, 2005 09:15 PM
Andrewuvm
Dec 16, 2004 01:00 PM
