Bad oil leak
Hello,
I bought a B6 2.4l last week and in the last few days a oil leak has been getting worse and worse. The car is a right hand drive and if I look underneath the car it seems to be coming from near the left side of the engine(if you are sitting in the car). At first I noticed it was just a few drops but now it is getting pretty bad, overnight it dropped about a 20cm puddle. The car is under warranty but what possible reasons are there for this kind of oil leak. |
So I'm guessint it's a diesel right? Keep checking the oil level and if you have a warranty have the place you bought it from check it.
Check the engine compartment to see if you see an obvious reason for the leak (i.e. the filler cap loose/not present) |
Originally Posted by Dan1969
(Post 1200367)
Check the engine compartment to see if you see an obvious reason for the leak (i.e. the filler cap loose/not present) I have checked the engine and transmission oil regularly and they seem to be at a good consistent level but the car is just leaking more and more. Here are a few photos. http://img52.imageshack.us/img52/4603/snc00033d.jpg http://img406.imageshack.us/img406/2650/snc00036p.jpg |
That seems to be coming from either the oild filter being loose or not having a gasket, or the drainplug loose or not having a gasket. Take the underbelly pan out and check the filter and the drainplug.
(Post 1200711)
There had a bit of oil around the oil filter but that has been cleaned up and I have left the underbelly pan off the car and am doing a few tests to see if it is coming from the filter. |
ok.
I cleaned the oil filter and then did a rev test keeping it at 2000rpm for about 10 minutes and I noticed oil was leaking from the oil filter so I guess I have found my problem. Thanks for the help. |
Make sure you put a new gasket on that bad boy.
