Bad oil leak
Old Apr 24, 2010 | 09:21 PM
vozduk's Avatar
Default Bad oil leak
Hello,
I bought a B6 2.4l last week and in the last few days a oil leak has been getting worse and worse.
The car is a right hand drive and if I look underneath the car it seems to be coming from near the left side of the engine(if you are sitting in the car). At first I noticed it was just a few drops but now it is getting pretty bad, overnight it dropped about a 20cm puddle.
The car is under warranty but what possible reasons are there for this kind of oil leak.
Old Apr 25, 2010 | 08:21 AM
Dan1969's Avatar
So I'm guessint it's a diesel right? Keep checking the oil level and if you have a warranty have the place you bought it from check it.
Check the engine compartment to see if you see an obvious reason for the leak (i.e. the filler cap loose/not present)
Old Apr 25, 2010 | 09:22 PM
vozduk's Avatar
It's not diesel.
I have checked the engine and transmission oil regularly and they seem to be at a good consistent level but the car is just leaking more and more.
Here are a few photos.
Old Apr 26, 2010 | 09:05 AM
Dan1969's Avatar
That seems to be coming from either the oild filter being loose or not having a gasket, or the drainplug loose or not having a gasket. Take the underbelly pan out and check the filter and the drainplug.
Old Apr 27, 2010 | 01:58 AM
vozduk's Avatar
Had the underbelly pan taken off and there had a fair bit of oil on it which seems to have originated from the front(near the oil filter) and then pushed back due to wind.
There had a bit of oil around the oil filter but that has been cleaned up and I have left the underbelly pan off the car and am doing a few tests to see if it is coming from the filter.
Old Apr 27, 2010 | 04:37 AM
vozduk's Avatar
ok.
I cleaned the oil filter and then did a rev test keeping it at 2000rpm for about 10 minutes and I noticed oil was leaking from the oil filter so I guess I have found my problem.
Thanks for the help.
Old May 2, 2010 | 01:19 AM
Dan1969's Avatar
Make sure you put a new gasket on that bad boy.
Octane567
Aug 8, 2014 10:28 AM
vtraudt
Feb 25, 2012 11:09 AM
mikeeboy82
Jun 13, 2009 11:09 PM
inventorA6
Apr 15, 2009 06:46 AM
