Battery Drain
Old Nov 16, 2014 | 03:38 PM
Kuyt's Avatar
Default Battery Drain
Hello.
Having a problem with my Audi A4 B6 2001(actually 2002 model but bought in 2001) causing the battery to get drained when the car is stood still.
My hazard light switch will stay illuminated at all hours and my key buttons will only work once every 100 clicks or something like that.
I have measured the drain to 0.7Amps.
When i disconnect the battery for 20-30 seconds, and lock the car the hazard light will turn off after 30 seconds and the key will work every single time i click a button on it. After i've reconnected the battery and turn the ignition on the same problem will emerge until i disconnect the battery again. The drain when i've disconnected the battery and not started the car again is 0.02Amps.
When i pulled fuse 24, the drain will drop to 0.08 after about 30 seconds, and then down to 0.02 after 1-2 minutes. When i reinsert the fuse it will continue to draw 0.7Amps at all times when the car is stood still, unlike when i disconnect the battery itself.
There are no fault codes stored in the system.
Any way to test the modules without swapping them out with a new ? Not to keen on replacing the CCM just to find out its actually some dumb little thing thats keeping it from going properly into sleep mode
Old Nov 23, 2014 | 04:21 PM
Kuyt's Avatar
Bump, edited to reflect the current situation of the car
Old Dec 12, 2014 | 11:29 AM
Rholly4's Avatar
Originally Posted by Kuyt
Hello.
I'm having the same problem.. Went to an audi specialists who said It was my speedo draining my battery.. I took my speedo cluster out for 2 days and tried to start it today and still doesn't work. Have you had any luck in resolving?
Old Dec 14, 2014 | 11:03 AM
Kuyt's Avatar
Having it in for diagnostics at an audi dealer as soon as i get the time, pretty sure it's the Comfort control module thats broken, but will see what audi dealer says after an hour of diag.
Old Dec 15, 2014 | 08:21 AM
Rholly4's Avatar
Where is the comfort control module? Is it under the steering wheel or the a/c unit?
Old Dec 16, 2014 | 10:51 AM
Kuyt's Avatar
Under the carpet on the drivers side if not UK. then its on the passenger side
Old Dec 17, 2014 | 05:37 PM
Rholly4's Avatar
Agh yes it's under the passenger side in uk. I've had mine tested they confirmed it was working perfectly so I'm back to square one
BWEBB1
Jan 31, 2015 09:08 AM
G13bsd
Jul 3, 2011 07:05 PM
Muzzlefump
Sep 4, 2010 01:32 PM
sswells
May 10, 2009 01:08 AM
billj
Nov 16, 2007 06:54 AM
