Beep at startup
Old Nov 4, 2008 | 12:12 PM
dmansr25sd's Avatar
Default Beep at startup
I am having the weirdest thing happen, when i start my 02 quattro I get a beep from somewhere around the rear center brake light. It beeps about 3 times in two seconds.
Things that happened in recent history of the car is i have been hauling a good bit of stuff recently in the trunk with the seats down, a coil pack went and was replaced by a shop and the engine trouble code cleared, and 3 weeks ago when the gas gauge went empty the gauge stuck there until i refilled after coming close to empty again.
I am not sure exactly when it started because it is only very audible when the seats are down in the rear, but i don't even have a clue what it might be and there are no warnings on the dash.
Old Nov 4, 2008 | 02:23 PM
GeneBopp's Avatar
If it beeps 3 times it might be a low battery warning for the alarm horn. I understand that you can replace the horn or cut it open your self and replace the rechargeable batteries.
Old Nov 5, 2008 | 01:56 AM
scskim's Avatar
when i went through 2 crappy batteries in a row, i got the 3 beeps at startup also. something concerning crappy battery maybe?
Old Nov 7, 2008 | 01:47 AM
dmansr25sd's Avatar
where would they be located, and i guess that might make sense because it appears to be the same horn as the alarm and the alarm horn is pretty pitiful sounding to begin with
RichardJohn
Aug 22, 2013 01:27 PM
Tremar
Jul 26, 2012 12:32 PM
shane@tm
Jun 18, 2010 11:16 AM
planetnb
Feb 29, 2008 04:57 AM
turbo
May 19, 2005 01:53 AM
